Will Del Sol Seats Bolt into a 99 Civic Si?
Old 02-11-2002, 08:58 PM
oldB18EF's Avatar
Default Will Del Sol Seats Bolt into a 99 Civic Si?
Bout to buy Del Sol seats off my buddy from his 93 sol, will they bolt right in to replace my stock seats or will I need something extra?
Old 02-11-2002, 09:01 PM
Troy's Avatar
Default Re: Will Del Sol Seats Bolt into a 99 Civic Si? (WRCivicsSiandEX)
yes they'll fit
Old 02-11-2002, 10:06 PM
The AntiRice's Avatar
Default Re: Will Del Sol Seats Bolt into a 99 Civic Si? (Troy)
they will fit, but you will have to *swap* rails from the civic seats in order to make the seat sit level and for all the holes to line up. There are instructions in detail how to do this probably been posted on this site, for sure ive see it on clubsi.com, but i hve these seats in my car as well, big improvement over stock. The only thing that sucks is the passenger seat no longer will flip and slide forward when you pull the handle on the seat, because the del sol had no back seats there is no mechanism for it to slide up like that. not that big a deal, ill take haveing to slide it manually over sitting on the stock seats anyday. HTH
Brian
Old 02-11-2002, 10:51 PM
beeboyee's Avatar
yes thay will fit, if you use the delly sol rails the nut closest to the arm rest wont bolt up, and you will be sitting very very low
Old 02-12-2002, 07:02 AM
evergruven's Avatar
Default Re: Will Del Sol Seats Bolt into a 99 Civic Si? (beeboyee)
thanks gamby... http://members.tripod.com/gamby123/id33.htm
jeffnerette
12
11-25-2008 05:52 AM
Nocturnal_Lude
10-16-2006 06:55 PM
Civic97s
03-23-2006 06:35 PM
dawrenn
03-30-2005 07:23 AM
BigZ88
22
06-19-2002 06:37 PM
Quick Reply: Will Del Sol Seats Bolt into a 99 Civic Si?
