will this brake swap work??
I tried the search button but came up with nothing. I have a friend who is selling his car to the wreckers. He offered to give me anything that is on the car. He has a 1991 Integra RS with a B18 conversion. Here are my Q's:
Can I swap the rear discs onto my 1994 hatch? Will the motormounts work on my hatch? Will his short throw shifter work on my hatch? What else can I take from his car? Suspension?? Modified by c_buz at 5:37 AM 7/7/2004 |
Re: will this brake swap work?? (c_buz)
C'mon guys little help here
you can take the lower control arms i believe for the brakes in the rear. but you may want to double check.
Re: (95civicracer)
where should I check??
Re: (c_buz)
I don't think it'll work. Not 100% sure though. If you had an ef or a crx then it'll work but not sure about the eg. But if he's just going to give it to you then take it... But don't forget about the brake master cylinder and proportion valve... Good luck
it will work i did it on my friends coupe all works good. The ebrake cable might need to be changed but that's it
take the interior: seats, etc and the motor.
Re: will this brake swap work?? (99FBPSi)
the motor has a blown head gasket. I don't know if it would be worth taking
If i was you, see what he is getting for the car from the junk yard, if its not to much buy it then part it out, and keep what you can us.
