Will the brake booster and master cylinder from a type R bolt in a 97 civic?
Sorry guys asked this a couple of days about but didn't get a definitive answer.
Re: Will the brake booster and master cylinder from a type R bolt in a 97 civic? (ekim952522000)
what brakes front & rear are you running?
I upgrade front & rear brakes to OEM 99-00 si...then upgraded just the MC to si b/c brake booster & prop valve are the same between DX & Si
Re: Will the brake booster and master cylinder from a type R bolt in a 97 civic? (adirondackR)
just about any civic brake swap question is answered here BTW
https://honda-tech.com/zerothread?id=152884
Be all end all, how can I put X brakes on Y car - thread
Im doing a 5 lug conversion with usdm type r brakes front and rear
for a H1 honda challenge car
the search button can be your bestest friend
"type r brakes" limit to 92-00 civic forum - archive topics
https://honda-tech.com/zerothread?id=1030989
"type r master" same limitations
https://honda-tech.com/zerothread?id=633953
beware of type R m/c's from ABS type Rs - lines are a different size
make sure you read the original thread I posted
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR »</TD></TR><TR><TD CLASS="quote">just about any civic brake swap question is answered here BTW
Be all end all, how can I put X brakes on Y car - thread</TD></TR></TABLE>
I am sure there is info about ITR brakes on EK in there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR »</TD></TR><TR><TD CLASS="quote">what brakes front & rear are you running?
I upgrade front & rear brakes to OEM 99-00 si...then upgraded just the MC to si b/c brake booster & prop valve are the same between DX & Si</TD></TR></TABLE>
.... the prop valve is different on the Si. It's a 40/40 valve vs a 70/30 for the disc/drum setup found on the CX/DX/LX/EX.
Re: Will the brake booster and master cylinder from a type R bolt in a 97 civic? (johnecon2001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnecon2001 »</TD></TR><TR><TD CLASS="quote">
.... the prop valve is different on the Si. It's a 40/40 valve vs a 70/30 for the disc/drum setup found on the CX/DX/LX/EX.</TD></TR></TABLE>
NOT FOR 96-00 CIVICS!!!!! my 97 (drum rear) & 2000 (drum rear)dx have the same prop valve as 1999-2000 civic si <--- all are 40/40 edit - may be wrong about all 96-00 but 96-00 dx prop valve is the same as 99-00 si!!!!!
look up the part #'s ...... I kept my DX prop valve with my SI brake swap (swapped brakes, m/c, ebrake lines)....the proportioning is done thru the MC
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=818263</TD></TR></TABLE>
damn good link for original post
Re: (adirondackR)
thanks for the help guys sorry i was being lazy about searching its just that i have read 20 threads on brakes today and could not find what i was looking for i appreciate the help
Re: (ekim952522000)
ok guys so I just finished stripping my type r today and the brake booster was hit thethe shock tower so it's toast.
HOw much are new type r ones?
Are the gsr brake boosters the same? will a gsr one work with a type r master cylinder in a ek? Whcih is best?
hunan beef
05-09-2011 03:43 PM
zerovandez
15
05-05-2007 11:20 PM
jimmhatch
07-17-2005 12:06 PM
