Will 94-01 Integra Steering wheels fit 96-00 civics?
I might pick up a steering wheel from a 2000 integra and put it on my 96, but i need to know if the wheel fits and if the airbag plugs are compatible? can anyone tell me if it will work? https://honda-tech.com/forums/images...es/emsmile.gif
Re: Will 94-01 Integra Steering wheels fit 96-00 civics? (RedMenace)
Not without modification, the hubs are different. I know this from the type R momo wheels.
I think the hubs are different. I think the Teg only fits in the 92-95 Civic, but I could definately be wrong.
Re: Will 94-01 Integra Steering wheels fit 96-00 civics? (Ricey McRicerton)
So will it work with a momo hub?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedMenace »</TD></TR><TR><TD CLASS="quote">So will it work with a momo hub? </TD></TR></TABLE>
No, I'm saying I know that Integra steering wheels don't work on 96-00 civics because my friend was trying to put an Integra Type R momo steering wheel on his car (a 97 civic) and it didn't work. |
Re: Will 94-01 Integra Steering wheels fit 96-00 civics? (smithenhiven)
Yeah, and i'm asking if you can install it onto the 96-00 with a momo hub. The steering wheel didn't work on your buddies car not because it was an Integra wheel, but he didn't have the right hub right? The itr wheel just happens to be made by momo right? I hope you see the difference..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedMenace »</TD></TR><TR><TD CLASS="quote">Yeah, and i'm asking if you can install it onto the 96-00 with a momo hub. The steering wheel didn't work on your buddies car not because it was an Integra wheel, but he didn't have the right hub right? The itr wheel just happens to be made by momo right? I hope you see the difference.. </TD></TR></TABLE>
It was the JDM Integra type R momo airbag wheel with hub for an Integra (hard to tell the difference between ITR momo and CTR momo), and it did not work. You need a 96-00 civic hub, or a CTR momo wheel, if you want the momo. So Integra steering wheel hubs are not compatible with 96-00 civics, but will work on 92-95's. So I guess you are correct, if you put a 96-00 civic steering wheel hub on a Integra steering wheel, it should work. it doesn't necessarily have to be a momo hub though. I hope we're both on the same page now https://honda-tech.com/forums/images...s/emsmilep.gif |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedMenace »</TD></TR><TR><TD CLASS="quote">Yeah, and i'm asking if you can install it onto the 96-00 with a momo hub. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedMenace »</TD></TR><TR><TD CLASS="quote">I might pick up a steering wheel from a 2000 integra and put it on my 96</TD></TR></TABLE> You can not interchange a Momo hub with a factory Integra steering wheel. |
Re: Will 94-01 Integra Steering wheels fit 96-00 civics? (Marauder)
so the consensus is it won't work then? thanks a lot guys https://honda-tech.com/forums/images...es/emsmile.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedMenace »</TD></TR><TR><TD CLASS="quote">so the consensus is it won't work then? thanks a lot guys https://honda-tech.com/forums/images...es/emsmile.gif </TD></TR></TABLE>
It definitely does not work. The '94-01 Integra hub is compatible with '92-95 Civic and '93-97 del Sol, but not the '96-00 Civic. You can, however, bolt a '97-01 CR-V, '97-01 Prelude, '96-04 Civic Type-R, '02-04 Civic Si, or '00-03 S2000 steering wheel directly onto the '96-00 Civic hub. |
Thanks for the info targa. That just gave me a lot more options for replacing my wheel.
Re: Will 94-01 Integra Steering wheels fit 96-00 civics? (Targa250R)
yes thanks a lot targa, now i know what i have to look for https://honda-tech.com/forums/images...es/emsmile.gif
Of course, it's not exactly hard to swap a steering column from an EG into an EK, so it can be made to work.
