will 90 teg ls rear lca's fit on an eg?
i believe its a 90-91 acura integra ls i was planning on putting the rear discs as well as the lca's will they fit
thanks
chris
thanks
chris
Re: will 90 teg ls rear lca's fit on an eg? (01VaS2K)
Yes, they will fit. I've done the swap on my EG. The only problem is, they will offset your rear wheels alittle. I didn't even notice until a friend of mine pointed it out. It's not enough to worry about. The tires still don't rub.
Colin
Colin
Re: will 90 teg ls rear lca's fit on an eg? (Canadian Hybrid)
offset as in negative or positive camber this could help or hurt in a way
thanks for the info
and also do i get the front mastercylinder or the rear from the teg?
lata
chris
thanks for the info
lata
chris
It won't effect your camber, just the offset. Your rear wheels will be further out, towards the fenders. I'm just using the stock master cylinder and it feels great. I would still consider the teg master cylinder a good idea though.
Colin
Colin
i have the chance to get either set of lca's what do you suggest i get? the 90 ls or 92-95? i will be running a progress swaybar so the teg lca's may actually be to long for them but i an unsure?
Mistermark
05-16-2006 12:46 PM
huge230
12-01-2005 02:55 PM
-DC2-
01-17-2003 10:48 AM
