Will 13" steelies from a 93 Civic fit on a 98 Civic?
Cogent Argument Enthusiast
I need to know ASAP. While driving at work tonight, I hit a 12 inch slab of broken concrete that was sticking up from the street. I pulled over and saw that one of my tires was completely flat and riding on the rim. Since it was a mile away from home, and I didn't have a spare with me, I just slowly drove home, because the 93 Civic I had bought recently came with a full set of stock steelies. I assumed they were 14" wheels, but when I went to get one they were 13". Since it is pouring out (of course, right?) I don't want to sit out there and change the wheel only to find out it won't fit on my EJ8. Does anybody know if the stock 13" steelies from a 92-95 will fit on a 96-00? I know from experience that wheels from an EF/CRX won't fit on a DA, even though they're the same size.
Re: Will 13" steelies from a 93 Civic fit on a 98 Civic? (Uncle Ben's)
A 13" rim will fit as long as it is not an civic EX. on an EX it wont clear the Brake caliper.
Re: Will 13" steelies from a 93 Civic fit on a 98 Civic? (95dxsir2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 »</TD></TR><TR><TD CLASS="quote">yes
4 on 100</TD></TR></TABLE>
Are you sure it will clear the drum or caliper? The threads and everything lined up when I went to put CRX Si wheels on my DA, but they didn't clear the caliper...
Re: Will 13" steelies from a 93 Civic fit on a 98 Civic? (Speed_1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed_1 »</TD></TR><TR><TD CLASS="quote">A 13" rim will fit as long as it is not an civic EX. on an EX it wont clear the Brake caliper.</TD></TR></TABLE>
It is an EX
It is an EX
Ok, that's not the only problem I have. The wheel won't come off the hub. I tried kicking the edges of the wheel about as hard as I can, and pounded on the edges all the way around with a bat. It still won't budge.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uncle Ben’s »</TD></TR><TR><TD CLASS="quote">Ok, that's not the only problem I have. The wheel won't come off the hub. I tried kicking the edges of the wheel about as hard as I can, and pounded on the edges all the way around with a bat. It still won't budge. </TD></TR></TABLE>
That's happened to me. I just went to a tire place and payed $10 for a tire rotation. Done!. It even works better if you bought your tires from a place that has free tire rotations with your purchase.
Re: Will 13" steelies from a 93 Civic fit on a 98 Civic? (old man neri)
get a hammer and a wood block, put the wood against the rim, and beat it with a hammer till the rim pops off. should only take 1 or 2 good hits.
Where in Wisconsin do u live...if u r close to me I might be able to come over and help (I have spare rims and tires).
Re: Will 13" steelies from a 93 Civic fit on a 98 Civic? (BearCatRacing07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BearCatRacing07 »</TD></TR><TR><TD CLASS="quote">Where in Wisconsin do u live...if u r close to me I might be able to come over and help (I have spare rims and tires).</TD></TR></TABLE>
I got it eventually after I put PB blaster in where the studs are, and then hammered it with a mallet. It came off after that, I think it rusted on there lol. If you have a 14" steelie with a halfway decent tire on there I'll pick it up from you for cheap. This tire has a 2" hole in it from the concrete
BTW the 13" wheel fit on the back hub just fine, no extra rolling resistance at all
joelmatt89
09-21-2009 01:47 PM
preciouscez
10
08-27-2004 10:10 PM
YipMan_Style
01-24-2002 08:19 AM
