Will a 08 Civic Si OEM Exhaust fit a EK Sedan?
Came across a fresh clean 08 Civic Si OEM exhaust and had been shopping around for a better flowing exhaust for my EK Sedan but wanted a quiet OEM style note with better flow... Picked it up for $60 bucks from the cat back to the tail pipe....
Wasn't gonna miss this and worse come to worse I just use the axel back muffler and get 08 Si exhaust flow
I'm running a Y8 complete exhaust manifold with cat, wondering if the bends are the same or bout the same? Anyone running this setup
My motor setup is a Y8 mini me done right with no shortcuts and no CEL, also no smog worries here in Indiana
Re: Will a 08 Civic Si OEM Exhaust fit a EK Sedan?
Lay it under the car with you and see whats up with it. Its most likely to long or to short in several places, the hangers are probably in way different locations too. I'd just do the axle back, or see if you can get a shop to run you a bigger pipe from your cat to axle, shouldnt be more than 60 bucks. so 120 altogether on your new shiny exhaust setup.
I'll get up under tomorrow and check, but if all fails them I'll just use the axel back and have the exhaust place run me some 2 1/4 piping from my cat back to the flange and bolt the axel back on
bleedblue94
Northeast (Sales)
11-12-2007 09:55 PM
peshte
03-19-2006 08:51 PM
