WHITE smoke from exhaust....
My '00 Civic coupe turbo has started smoking a little from the turbo, and violently (thick white smoke) from the exhaust. It occurs about a minute after starting the engine and then on and off whenever I drive it. I noticed the coolant and the oil disappearing, but not necessarily leaking on the ground. Car shows no sign of overheating. Do I have a blown head gasket??
Please help…
Please help…
Re: WHITE smoke from exhaust.... (drex00)
Don't drive your car anymore, you can warp the head and cause more damage than already done. You will likely need the head resurfaced and you just need to order a new headgasket/bolts.
buy a book d series motors are cake take a couple hours tops little suggestion though get a cometic gasket and some arp head studs will give you better chance tht this wont happen again
Re: WHITE smoke from exhaust.... (hybridmath)
Sounds like a headgasket. I just replaced mine. It was $120 for a complete gasket set and $160 for the headwork. Its not a hardjob to do but it was time consuming for me. Good luck
Yep blown head gasket and your burin oil. VERY bad for the engine's health. But I think its worth getting replaced. (Get a K20A baby!!!)
it's a easy fix, but since you been driving it I would get it tested and shaved. You can go to almost any part store and they have a lil black book that will give you the specs and sequence for the head bolts.
redzcstandardhatch
08-26-2004 09:32 AM
youngkow
12-27-2003 12:18 PM
