white smoke?
Re: white smoke? (Ejsleepin)
got any text in your post there? White smoke. I've seen it before. Its stinks too! I mean DAMN DUDE! POST A THREAD NOT A TITLE!
dont get me wrong...isnt' white smoke generally coolant? maybe his headgaskets leaking..when i was buring oil it was like bluish white or black..kinda like that black smoke when your running too rich at WOT poof out it comes..lol..for people who went turbo ya'lls know what i'm talkin about..lol
Re: (JRI94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 »</TD></TR><TR><TD CLASS="quote">I get just a puff when I get off the line autoxing or if I drop down a gear from like 3000 rpms. Any idea? Sorry to jack.</TD></TR></TABLE>
of what white or black smoke? my friends stock b16 del sol would do that at times when we and played around at the round-a-bouts but figured the oil is sloshing around in there too much...lol
Re: (delslowed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslowed »</TD></TR><TR><TD CLASS="quote">...but figured the oil is sloshing around in there too much...lol </TD></TR></TABLE>
I could buy that as a reason. It's mainly when I autox and I don't have an oil pan baffle.
Re: (Uncle Ben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uncle Ben »</TD></TR><TR><TD CLASS="quote">Lol..and I sat here for like 2 minutes waiting for a pic to show up...</TD></TR></TABLE>
I took 3rd in the novice class that day
Re: (JRI94)
White somke can mean various things.......But my guess would be that the problem lies not in the oil, but in the fuel distribution. White smoke is usually a sign of running to lean. In this case sheck your injectors to see if they may be clogged or do a leakdown test to see if it involves the rings.
Only advice i can give you
Re: (HyprEGhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyprEGhb »</TD></TR><TR><TD CLASS="quote">Head gasket probably</TD></TR></TABLE>
You say that because of a small puff of white smoke? If the head gasket was blown you'd know it and it would be a bit worse than a small puff of white smoke.
Re: (Uncle Ben)
damn, he got me too.
Re: (Cruiser G)
my coolant levels are good, and the coolant is still the bright green color. i also did a compression test not too long ago and they were all real high. i dont know what else it could be. i mean im leaking oil but its not from burning oil, i have oil coming out of the distributor cap( i know its bad, im changing it out soon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ejsleepin »</TD></TR><TR><TD CLASS="quote">well, white smoke is usually a sign of burning oil. you might have damaged a ring or two.</TD></TR></TABLE>
I am going to assume that you meant coolant, and head gasket, right?
Re: white smoke? (Damon)
I just changed my radiator about a month or so ago. I'm not losing any coolant, my temperature guage ALWAYS sits about 3/8 of the way up and my gas milage rocks. I don't burn any oil either. ???
