where to tap power from the climate control and speedometer lights
I have an extra light that I want it to light up when my climate control panel turns on along with the speedometer. where can I the power wire to tap or is there a better way to get power but I want it to turn on along with the climate control lights..
I have a 2000 civic..
thanks
thanks
Re: where to tap power from the climate control and speedometer lights (Sam268)
got a helms? that would help you out alot. I think that you want something to light up when you turn your lights on no? if so im pretty sure you can just attach whatever you want to hook up to a red/blk wire. thats a red wire with a black stripe. if you look underneath the dash it should be wired into your dimmer switch or pretty much any switch you got with a light on it, just tap that ****.
jdmrexy90
12-16-2012 11:36 AM
xxh23fuzionxx
08-13-2003 04:53 PM
