Where is molybdenum disulfide grease for the clutch system sold?
The manual for my civic says to apply molybdenum disulfide grease to various clutch components such as where the clutch slave cylinder makes contact with the clutch fork.
I went to a couple auto parts stores and no one seems to know what it is...
So does anyone know where I can buy it and also where can I buy silicone grease in a tub?
Re: Where is molybdenum disulfide grease for the clutch system sold?
I get mine directly from Honda. If you need, I can look at mine and give you the part number. Otherwise, just go to Honda and tell them you need some.
I just use bearing grease. Used that for slave cylinder, axles etc. Never had a problem.
I picked up some at autozone,though it's not called that..
The brand is "Coastal" and it's called "moly ep grease",,however when you read the back is says molybdenum disulfide.
edit - they have it listed on the website
http://www.autozone.com/autozone/cat...uestid=1776789
http://www.autozone.com/autozone/cat...ndName=Coastal
I use sta-lube and just checked the back and, sure enough. SAME ****. Never even thought to look. Just the stuff I've been using for years never knew the actual name.
Thanks for the help everyone,I went ahead and bought the coastal moly ep grease and it looks like it's the right stuff.
autozone, based, buy, clutch, coastal, dissulfide, disulfide, ep, grease, honda, molbdenum, moly, molybdenum, molybdenumdisulfide, yamaha
