which where # of gear (s4c)
Old 02-21-2018, 10:26 PM
D1mas's Avatar
Default which where # of gear (s4c)
Hi guys, help to recognize gears!
Old 02-22-2018, 08:19 PM
JRCivic1's Avatar
Default Re: which where # of gear (s4c)
Yep... they look like gears.
Old 02-22-2018, 09:33 PM
D1mas's Avatar
yeah, but which numbers of these gears?
Old 02-23-2018, 03:17 AM
Corvette Forum Member
LiteraCola's Avatar
Old 02-23-2018, 05:05 AM
mk378's Avatar
Those look like parts of a D-series 5 speed. Based on that assumption:
The service manual must be consulted, because there are several nuances about the parts where they can be put together wrong.
It would have been good to take pictures before taking apart, or find someone else's pictures of the shafts assembled.
The dealer parts identification exploded view shows the order of assembly of the parts.
As a start, the two largest clutched gears go on the inside (engine end, the bottom if you have the transmission sitting engine side down on a bench) of the output shaft. The 1-2 clutch is in between them. The 1-2 clutch also carries the reverse output gear. The other three gears on the output shaft are fixed. The input shaft has the fixed first gear made into the shaft, this is followed by the fixed reverse gear and the fixed second gear (smallest fixed gear). Then the third clutched gear, 3-4 clutch, fourth clutched gear, fifth clutched gear, and the 5 clutch.
Keep your gears clean. Don't lay them on the ground.
vtecn8ive
Transmission & Drivetrain
07-25-2009 11:02 AM
aasaa666
04-26-2009 09:09 PM
pghbricklayer
Honda Motorcycles
06-18-2007 06:43 PM
SPOON 1
04-16-2004 12:50 PM
Quick Reply: which where # of gear (s4c)
