Where is the alternator fuse on my EK?
like it says guys, is it under the dash? i am throwing cel 20(electrical load detector)
and cel 17(speed sensor). when i drive my lights get really dim and my car turns off. at the time my speedo is not working. I got a new alternator and reaplaced a fuse under the hood. do you guys know where the alternator fuse is?
Info: 99 civic with a gsr swap. thanks for your input.
BTW can my ecu be causing the problem?(p28 chipped with the jun program)
Re: Where is the alternator fuse on my EK? (jaydm ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydm ferio »</TD></TR><TR><TD CLASS="quote">like it says guys, is it under the dash? i am throwing cel 20(electrical load detector)
BTW can my ecu be causing the problem?(p28 chipped with the jun program)</TD></TR></TABLE>
There is no fuse for the alternator, heh, it gets power directly from the battery my friend. I'd say it's likely the ECU could be causing troubles, yes.
Give me your email address and I will forward you PDFs from the service manual to troubleshoot your two issues.
If you have access to the service manual yourself, look up the following Diagnostic Trouble Codes...
P1297: Electrical Load Detector (ELD) Low Input Voltage
P1298: Electrical Load Detector (ELD) High Input Voltage
P0500: Vehicle Speed Sensor (VSS) Circuit Malfunction
UpstateCivic
04-15-2004 03:22 PM
