Where to adjust idel rpm.
the engine of my eg idels a bit higher when engine reaches at normal working temp.it idels at 1200 rpm (b16a engine).where can i adjust the engine idel?
thanks
thanks
Re: Where to adjust idel rpm. (crazyguy)
idle.. you need to do this with a digital tach or timing light. let the engine warm up till the cooling fan cycles on. jump the two pin connector under the dash. this is the same one you jump to check the CEL. set the ignition timing.
then undo the two pin connector under the dash and only for a moment pull the connector to the iacv loose and check the timing. if you don't see something different on one of the hood labels i think you should see 450 + or- 50 rpm, with it unplugged. plugged in you should see 720 + or- 50 rpm. again, check your underhood info labels.
if it's not right there is a flat head screw on the TB. it sometimes has grey RTV covering it. turn this a quarter turn at a time and the check your reading on you digital tach or timing light. that's all.
P@@RB@Y
12-12-2005 03:56 PM
