Wheel and tire questions???
I know im probably going to get scolded for these questions because im sure its posted somewhere on here lol....just getting in to the whole suspension tire side of things n need some clarification
What is the widest tire u can go with on a stock civic without rubbing????
how do u change the offset of a tire?
and the bolt pattern? what exactly is 4x100 i kno the size is in .mm what what does it stand for? Thanks for the help
Re: Wheel and tire questions???
4x100 is the number of wheel studs/lugs (4) and the distance they're separated (100 mm). All 92-00 Civics use this configuration unless they have been given a 5 lug swap.
I wouldn't go above 205 for tire width, I run 205/50/15, no rubbing and very grippy (Dunlop Direzzas).
Different wheels have different offsets. If you want to change this, buy new wheels, or I guess you could add spacers (not really recommended).
Also, try using google or our search engine on here next time, and check the wheel and tire forum area, there's lots more info about all of this.
