wheel studs
wheel studs
ok so i bought my car with 2 studs broken... now i broke one more but it wasnt bad enuff so i still fit the nut on it but damn im running out of lug nuts... where's the best place to buy them the dealer? and one of the studs that are not broken the threads are getting messed up on so im guessing those are getting ready to break also... i never even use my impact gun to take them off anymore because im paranoid lol
Re: wheel studs (Midori Green)
Changed some on a '34 Ford rear end being used for a trailer axle once. Lot's and lots of PB Catalyst and a 2lb baby sledge got it done fairly quickly. The Ford had a flat spot on the stud heads to match a ridge on the back side of the mounting surface. Had to make sure that lined up. I don't know if Honda has the same ridge or not. When you get the old ones out you'll see that flat spot on the head if it's there.
Banned
you have to go to autozone to rent a slide hammer with the wheel stud adapter. You just place the the stud adapter on the studs (your wheels are taken off) and attach the slide hammer to the adapter and just yank out the hub, then you hammer out the old broken stud and replace it with your new ones.
