wheel rub help
wheel rub help
car is a 94 civic hatch
the drivers side rear wheel rubs up against what i think/sound like the outter edge of the wheel well, suspension is stock and wheels are grs swirlies, with 195/55/15 tires..if i hit a dip or take a hard right turn it will rub, can this be an alignment issue, the steering wheel is a lil off center when going straight, and it doesnt pull hard to either side when u let the steering wheel go..it looks like it may be rubbing at the back of the rear wheel well wher the bumper and quarter panel meet, where the bolt hold the bumper on right there, there seems to be a peice of that bracket or what ever sticking into the path of the tire when the shock is compressed, any ideas, im going to cut a peice off that bracket to see if it helps, but wanted ideas...and to think i wanted to lower the car..
and at full lock the front drivers side wheel rubs inside the wheel well somewhere, not bad but i hear it against the fender liner, can blown shocks be a part of the culprit? car has 144,xxx miles, everything original..
thanks..
thanks..
Imperious: Mod of Valor
Re: wheel rub help (dip-set)
I was going to say "raise your car" but that's not the case lol. When you hit a dip your car is going to get lower for the length of the dip/bump/etc. I had my car dumped like 3.5" one time, I rubbed just when turning. It never caused an alignment issue though.
Re: wheel rub help (JDM-EJ1)
not can the rubbing cause an alignment issue, can an alignment issue cause the rubbing, to much toe in or toe out in the rear maybe is what im guessing...
any better answers?
thanks..
any better answers?
thanks..
Sorry reading too fast. I don't think alignment could cause rubbing, I would think the camber would cause it more.. Like, instead of you wheels just being like turned a little but (bad alignment), I don't see how that would cause it.
Because you turn everyday and you said it doesn't rub. However if you had bad camber, wheels like / \ instead of | |, I could see how that would cause it. But you said you had stock suspension, so we can probably dismiss that idea.
If your really worried about it (I don't see why you should be) my car rubbed everyday and I didn't think twice about it.
lol horrible...new shocks and springs are in the mix of things i need but even with blown shocks at factory height, i didnt think it would rub...
arren123
06-07-2006 05:11 AM
A Blue Lude
11-01-2005 11:45 AM
