Wheel Hub and Bearing
Replacing several parts for my suspension overhaul. I would like to confirm fitments of some parts.
Im going to be replacing the bearings of all 4 wheels. Civic DX in front and 94-01 Integra in back.
For the bearings, are all the bearings swapable from trim to trim and from civic to integra?
Front bearing
http://cgi.ebay.com/ebaymotors...l1259
Rear bearing
Will these parts fit?
And I need a Rear Trailing Arm bushing for my rear discs. Will the bushing for an 88-00 civic fit in the integra?
Referrring to this product:
Thanks alot
Matt
Front bearing
Rear bearing
Thanks alot
Matt
Re: Wheel Hub and Bearing (Abius)
your just asking for trouble. what if you get the wrong bearing? ebay is the last place you should be buying parts that important from. pay the extra cash and at least go to your local, napa, autozone.... at least you can take your old bearing into the autoparts store to verify. ebay get a big from me for parts that should be bought at the dealer.
Re: Wheel Hub and Bearing (ivan93egreppin210)
Ya, after realizing what Im getting into, Im just going to go OEM thru yoparts.com
But either way, what about for the trailing arm bushing?
Dont see any made for integra.
It should fit. THis one states that it fits both integra and civic. So, if that one fits both, then this one should fit both.
http://cgi.ebay.com/ebaymotors...l1247
Modified by Abius at 7:50 PM 7/2/2008
have you check pricing to replace rear bearings and bushings?
i bet it'll be cheaper to find a replacement set from a junkyard, honestly.
and why are you replacing your rear bearings? are they bad?
you may as well get some nice extended lugs while you're doing it, the hubs'll be off anyway.
Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">have you check pricing to replace rear bearings and bushings?
you may as well get some nice extended lugs while you're doing it, the hubs'll be off anyway.</TD></TR></TABLE>
New studs and lugs already purchased
JDogg
Suspension & Brakes
04-12-2008 08:57 AM
redman223
04-30-2007 02:36 PM
