Wheel Bearing?!! How To??
Search is down and i cant figure out how to press the wheel bearing out. (front/back) are there any write ups? or can some1 explain how to do this?
Thanks in advance HT.
Re: Wheel Bearing?!! How To??
not to patronize... but you use a press to press them out.
what i usually do is pull the knuckle off if it's the front and set it up on a shop press. you'll have to improvize the press jig (very large sockets, old wheel bearings, anything sturdy and round..)
on the back- you can in some instances loosen all the bolts, but leave them in about half-way threaded. soak the bearing OD in penetrating oil/spray and begin tapping the bolts with a hammer to knock it out. i would start lightly, in a cris-cross pattern, slowly increasing force untill it pops loose.
dissclaimer: these are my general suggestions under the assumption that you have prior mechanical abilities and sense. if you have any uncertianty as to what to do after reading, have a compentent friend help or invest in a good repair manual.
remember with any of the methods available, safety glasses are a must.
Yeah, for the front, pull off the knuckle and bring it to a shop, where for a nominal fee they will press out the hub and bearing and press in the new bearing.
You can do the rear bearing yourself as it is integrated with the hub. You simply replace the whole hub/bearing unit.
i have a hydrolic press at my job but i couldnt figure out how to press the bearing out from the front of the knuckle. so i took it to the machine shop next door $35 fix haha
z6hatchboy
02-06-2009 06:31 PM
Archie_G
11-18-2003 01:39 PM
