Whats wrong with my car????help.
Okay when ever i try to start it, it won't start. It won't crank or anything. I know it's not the battery because i tried boosting it and same problem it just won't crank at all, i even changed the battery. Sometimes it'll crank and start and some other times it will just do nothing. Whats wrong with it???
No engine mods. Sohc 1.5l engine. |
So it makes no noise at all? If so could be a main relay.
Re: Whats wrong with my car????help. (SpdFrk)
Do you hear a clicking noise when it won't start?
Re: Whats wrong with my car????help. (JV)
nope no clicking noise.
main relay prolly
if there is not clicking sound then that means that its the starter....no workie....usually it would click over if it wasnt the starter.....
could be the main relay, they usually go bad......if it is the main relay, get a new years civic's relay because they are better....thats it... |
try to get a metal bar of some sort and tap the starter while someone else turns the key. if this works, then your starter is sticking and u need a new one.
Re: (dgonzals)
Alright thanks guys. So i can grab like a 00 civic main relay? What about the starter? can i use a newer model starter aswell or would i have to get a 92-95 starter?
Re: (SpdFrk)
Also if anyone could- would u be so kind as to post up the part number of the main relay and starter i would need from http://www.hondaautomotiveparts.com
Thanks. |
