Whats needed for hub conversion from Sol to Teg
Ive a jdm Sir Delsol, which is 4*100. I want to put 96Integra type R wheels on it which require 4*114 fitment. So basically i need 96 spec Itr hubs and other bits. Im not familiar with such parts so can someone tell me exactly what ill need to buy off a Teg?
FRONT
My delsol currently has Prelude calipers and Rover 282mm disks on the front.
So if i buy the Itr front hubs and trailing arm, and buy new Prelude 282mm disks which will be 4*114, I should be able to re-use my current prelude caliper, yeah?
The rear of the delsol is standard.
Am i right in thinking a 96Itr has 262mm front disks and 242mm rears? And the delsol has the same setup with 242 rears?? Does this mean i just need to buy the Tegs rear hub and then fit a 242mm integra disk and this should work ok with my standard delsol caliper, yeah? Ive also been told that "the rear wheelbearing/hub of the 96Teg slots on to a vti/sir delsol trailing arm and thats all ill need to do for the rear, and just fit a teg brake disc". Is this correct?
So to summarise, i only need to buy the following parts/components:
1 - Integra Front trailing arms and hub assembley
2 - Rear Teg hubs
3 - Prelude 282mm front disks & Teg rear 242mm disks
Is that right, anyone care to confirm all this or point out anything else ill need, are there any other suspension rods/arms etc,,, ill need?
I'd appreciate any advice on this before i buy the parts this week.
FRONT
2 - Rear Teg hubs
Re: Whats needed for hub conversion from Sol to Teg
Ive searched around and not really come across much on this, can anyone at least confirm if my standard rear calipers can be used with the integras rear disk.
NonovUrbizniz
28
03-02-2004 04:54 PM
ef civic
06-08-2003 12:09 AM
