Whats missing?
Whats missing?
So I just bought a 92 Civic CX with a d15b7 in it. Which I believe came out of a del sol. I've never messed with a motor like this, so can you tell me what is missing in these pics. I'm not sure what is suppose to go where this hole and bolt holes are.
Re: Whats missing?
What is stamped on the front of the engine, dizzy side, a little below the level of the dizzy?
Edit: sp00ledbseries, ED9Got_Vtec and onereving7 are right: The USDM D15B7 comes with that hole but it is blocked off, presumably neatly at the factory. So a rag should go in there only about one inch. Other D15B engines have or had carburetors and the hole gave access to a lobe on the camshaft to mechanically drive a fuel pump. My D15B (nonvtec, swap shipped from Japan) has the hole but the block-off plate is much more prominent (held on with two bolts, for one thing), I gather indicating the engine swap company put it there when it got modified to MPFI, like what is described at
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/what-motor-pm3-8-d15b-2082366/.
Re: Whats missing?
The block is for sure a d15b7 it's stamped with it. However the head could be a different head. The guy told me it wasn't, that the motor just came out of a del sol but who knows.
Re: Whats missing?
There is supposed to be a cover there like on a b18b non vtec all the heads and block are a generic cast so they juss block off or open new ports in the motor for the application its for
Re: Whats missing?
Re: Whats missing?
If you can put a rag through that hole and it comes out oily, block it off with a plate to fit.
Re: Whats missing?
On the front of the head near #4 exhaust port there should be numbers like PM3-8 stamped. This might tell you a bit more, especially if you are trying to tune this engine.
Yeah I know. It went bad so I'm replacing it.
Re: Whats missing?
Nothing is missing. Some d15b7's else where in the world were carburated, and that is a mounting place for a mechancial fuel pump. Your car does not need it, and there was never a cover. Fix the damn oil leaks though
Re: Whats missing?
The oil leak is fixed. I drove it 4hrs home and the guy i bought it from didn't tell me the seal on the oil cap was completely gone. So when i checked it about halfway through the drive oil had leaked out everywhere.
SRASC
Transmission & Drivetrain
11
09-10-2019 05:58 AM
Speed_Racer
12-17-2002 06:58 PM
