whats making my front end vibrate?
I noticed the other day while driving that my front end vibrates and pulls to the left. I have had a recent alignment due to replaced tierod but, still doing it. what is the cause of this? I'm thing ball joints or struts maybe both
Re: whats making my front end vibrate?
what kind of vibrating?? does it only vibrate when turning left or right? or does it vibrate consistently?
Check for any torn boots on the ball joints, axle, tie rods etc. |
does it do it when you hit your brakes? or just while driving?
its probably your rotors, i had the same problem and when i did my brakes and rotors my it drove smooth.
i was just going to say rotors is it bad when you hit the brakes?
does it vibrate at certain speeds?
or when braking? if it pulls at any time. tires are worn out unevenly if at certain speed the vibrating is most likely a balance issue. get your tires checked and re-balanced. if vibrating when braking. it's the rotors. probably warped. |
Originally Posted by MJ 95 del sol
(Post 48644276)
Assuming that its when your driving then..... If you had an alignment done recently and this drove straight afterwards and now its starting to pull. Its your left tire that is low on air, that would cause your car to vibrate and pull to the left. |
Thanks guys...It doesn't pull or vibrate while braking but i know my brakes need changed so i may change rotors also and check my boots and balljoints etc. It does it more when i hit bumps.. would that be struts?
maybe something is bent?
Torque the lugs to spec. Most shops waaaay over-torque the lugs.
Originally Posted by strategy400
(Post 48657918)
