whats the horsepower on a d15b7 engine?
i just checked my del sol and it said d15b7, i thought i had a d16z6, but i guess not. and i was wondering if my engine is vtec, too. I don't even know why i am asking that, i know it is, but whatever. i guess i have the S version, for all this time, i was mistaken. I guess i am going to be buying the b16a3 soon then.
dAng!
Re: whats the horsepower on a d15b7 engine? (KodSol)
if you have the del sol s, it's 106 hp.
if you have the del sol si, it's 127 hp. VTEC solenoid will be located between the valve cover and the firewall about one inch from the head on the passenger side of the motor.
Re: whats the horsepower on a d15b7 engine? (Russ713)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Russ713 »</TD></TR><TR><TD CLASS="quote">if you have the del sol s, it's 106 hp.
if you have the del sol si, it's 127 hp. VTEC solenoid will be located between the valve cover and the firewall about one inch from the head on the passenger side of the motor.</TD></TR></TABLE>
102 HP for a D15B7, 106 HP for a D16Y7
Re: whats the horsepower on a d15b7 engine? (BlueIntegraBoy)
thanks, i can't believe i didn't know that i had this motor. good thing i didn't buy those headers from that guy, this sucks, i need a new motor.
Motor, ecu, & wires on harness to be exact. The other option is a cheap turbo kit. By the time you blow it with 10psi, you'll have the cash to bump up to a z6 or a b-series.
The other route would be a mini-me head swap. IIRC, you'd get a comp ratio of 9.6 with the z6 head on the b7 block, which would give the same hp as a d16z6 due to a bit more compression.
dAng!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KodSol »</TD></TR><TR><TD CLASS="quote">thanks, i can't believe i didn't know that i had this motor. good thing i didn't buy those headers from that guy, this sucks, i need a new motor. </TD></TR></TABLE>
it's header btw, not headers. Either way, if the header was for a d series motor, you'd have been fine. They both fit.
no, you don't have VTEC. can't believe i always have to repeat myself.
93-97 Del Sol's in US spec...
93-95 Del Sol's (OBD1):
Del Sol S - D15B7 SOHC non-VTEC - 102hp 98lbs/ft tq
Del Sol Si - D16Z6 SOHC VTEC - 125hp 106lbs/ft tq
94-95 Del Sol VTEC - B16A3 DOHC VTEC - 160hp 111lbs/ft tq
96-97 Del Sol's (OBD2a):
Del Sol S - D16Y7 SOHC non-VTEC - 106hp 103lbs/ft tq
Del Sol Si - D16Y8 SOHC VTEC - 127hp 107lbs/ft tq
Del Sol VTEC - B16A2 DOHC VTEC - 160hp 111lbs/ft tq
H-T Order of Merit
Re: whats the horsepower on a d15b7 engine? (skip.two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skip.two »</TD></TR><TR><TD CLASS="quote">no, you don't have VTEC. can't believe i always have to repeat myself.</TD></TR></TABLE>
The trick is to assign macro keys with your typical responses.
Zmoody12345
29
01-27-2016 09:59 AM
GreenTeaLS
04-20-2005 03:44 PM
Spool Me Up
09-13-2003 03:53 PM
