whats the diffrence?
between gs-r cam gears and itr cam gears. will i gain any power if swap the gs-r and put the itr cams gears on. its an b18c with i/h/e
Re: whats the diffrence? (drvfast)
the ITR cams have more duration and a little more lift. You will see a difference but be sure to get oo.o1 ITR cams as they have the most duration and are identical to CTR cams.
Get a VAFC and tune the fuel when you get them
Re: whats the diffrence? (B_Cruz)
between gs-r cam gears and itr cam gears. will i gain any power if swap the gs-r and put the itr cams gears on. its an b18c with i/h/e no difference in power.
Have to disagree. I have seen a power difference between a 98 and 2000 type-R intake cam so I know they will make more power than a GSR cam which makes less power than a 98 ITR cam. Intake cam is the only one of concern
Re: whats the diffrence? (Ghia)
Changing gears will do nothing. If you change the cams though, make sure you upgrade your valve train too. ITR valve springs and retainers should do.
