whats the correct ecu for for jdm sirII b16 motor?
im trying to get my sticker form the ref for a legit swap, i heard u need to use a usdm ecu for the swaps, am i correct? which would be the correct one to use? thanks
im think im using a p30 right now, but im not sure, have to check again! thanks |
Re: whats the correct ecu for for jdm sirII b16 motor? (stripes777)
well if you wanna run a usdm ecu try gettin a hold of a delsol dohc vtec
ecu. i believe on the box it should denote p30-ao1 for us spec b16 ecu. |
Re: whats the correct ecu for for jdm sirII b16 motor? (djhatch)
i was using a obd1 pr3 ecu
Re: whats the correct ecu for for jdm sirII b16 motor? (redline201)
thanks guys, i rememebr already using the p30, yay! no need to spend money! new longblock swap is going in next saturday!
will the usdm b16a2 ecu also work for the jdm sirII b16 motor?
Re: whats the correct ecu for for jdm sirII b16 motor? (kpop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpop »</TD></TR><TR><TD CLASS="quote">will the usdm b16a2 ecu also work for the jdm sirII b16 motor?</TD></TR></TABLE>
Yes but it might run just slightly lean. Probably not enough to cause a problem. I am running a usdm gsr ecu on my jdm gsr and its fine. Thats basically doing the same thing. |
You need the USDM P30 not the JDM P30. You'll be able to tell through the numbers here: https://honda-tech.com/zerothre...57564
And the JDM P30 looks a lot smaller in size than the USDM P30 and most other ECUs |
