whats the best oil for my eg
Re: whats the best oil for my eg (MidwestSi)
i have the same car and i use castrol full synthetic. works great and last longer than regular oil. brands dont really matter just make sure use full synthetic.
If the motor has not been broken in: Valvoline Racing 20-50 (Regular not Synthetic) Should say VR-1 on it.
If the motor has been broken in but not built for racing:
Mobile 1 Full Synthetic
If the motor has been broken in and is built for NA or Turbo:
AMSOIL
RedLine
Keep in mind that if the motor has not been fullly built for racing, it probably won't matter which synthetic you choose. Mobile 1 goes for about $4 a bottle, the others probably double or triple that (Obviously I do not buy the others).
AMSOIL
RedLine
Re: whats the best oil for my eg (civic_tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_tuner »</TD></TR><TR><TD CLASS="quote">mobil 1 synthetic </TD></TR></TABLE>
x2
x2
Re: whats the best oil for my eg (JDMlifestyle)
Amsoil, Royal Purple, Moble 1 are my favs. However dino Pennzoil will probably be just as good and run you $18 a change vs $40.
I used to use Mobil 1 synthetic and change my oil every 3,000. I got tired of paying ~$30 for every oil change. Now I just use Castrol GTX and change it every 2,500. It works fine, can't even tell a difference.
I think Mobil 1 syn is a waste of money unless your changing you oil every 6,000+ miles.
be professional
Re: whats the best oil for my eg (fakemike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fakemike »</TD></TR><TR><TD CLASS="quote">I used to use Mobil 1 synthetic and change my oil every 3,000. I got tired of paying ~$30 for every oil change. Now I just use Castrol GTX and change it every 2,500. It works fine, can't even tell a difference.
I think Mobil 1 syn is a waste of money unless your changing you oil every 6,000+ miles.</TD></TR></TABLE>
My thoughts exactly.
I change my oil every 3500 miles with Castrol GTX 10W-30. Half the price of synthetic, and doesn't burn off as easily either.
Synthetic is a total waste of money if you're changing oil every 3500 miles or sooner on an NA engine with stock internals.
If anyone wants proof, my CRX has 235,000 miles of it right here . . .
Re: whats the best oil for my eg (pancake56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chronodyne28 »</TD></TR><TR><TD CLASS="quote">This topic has been killed over and over. Search.....</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chronodyne28 »</TD></TR><TR><TD CLASS="quote">This topic has been killed over and over. Search.....</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chronodyne28 »</TD></TR><TR><TD CLASS="quote">This topic has been killed over and over. Search.....</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chronodyne28 »</TD></TR><TR><TD CLASS="quote">This topic has been killed over and over. Search.....</TD></TR></TABLE>
Re: whats the best oil for my eg (2thousandcivic)
if its a repeat and i should have search then why are you wasting your time to read this thread and put your two cents in
Oil Manufacturers Data Sheets:
https://honda-tech.com/zerothread?id=778788
Some Good Writeups and General Information Regarding Engine Oil:
https://honda-tech.com/zerothread?id=778792
https://honda-tech.com/zerothread?id=163845 - General Discussion
https://honda-tech.com/zerothre...54666 - General Information
https://honda-tech.com/zerothread?id=755474 - General Discussion
https://honda-tech.com/zerothread?id=736572 - General Discussion
https://honda-tech.com/zerothre...34928 - General Information
https://honda-tech.com/zerothread?id=735436 - General Discussion
https://honda-tech.com/zerothread?id=155706 - General Discussion - Racing Oils
https://honda-tech.com/zerothread?id=848572 - General Discussion
https://honda-tech.com/zerothre...39688 - Synthetic Oils
