what write up should i do next?
Well i have some times on my hand. just wondering what kind of write ups u would like to see. place your vote
Re: what write up should i do next? (JDMlifestyle)
How about a LS1 in a RX-7 (FC)
Make sure you wire the fan switch with a relay and in-line fuse (if you do it)
Re: what write up should i do next? (VtecDeMoN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecDeMoN »</TD></TR><TR><TD CLASS="quote">Personally I don't think either need a write up. Save your efforts for something better.
Brian</TD></TR></TABLE>
Unceasing Measure
Re: what write up should i do next? (Sl0wEH2)
Or do both at the same time, save some space, and teach the newbies how to do these things. Not everyone comes out of the womb with a head full of car ****, guys.
External coil is a waste of time. Stock ignition system is fine.
And instead of doing a manual fan switch right up, why not showing people how to diagnose and replace their fan switches? Seems like a much better idea then doing a write-up for a half assed way of fixing something that is not working.
Re: what write up should i do next? (RedlinedVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC »</TD></TR><TR><TD CLASS="quote">External coil is a waste of time. Stock ignition system is fine.
.</TD></TR></TABLE>
no it's not when u don't have internal coil in ur dizzy (like me ) and need to put an external coil in.....
.</TD></TR></TABLE>
Re: what write up should i do next? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Or do both at the same time, save some space, and teach the newbies how to do these things. Not everyone comes out of the womb with a head full of car ****, guys.</TD></TR></TABLE>
True
True
Re: what write up should i do next? (4DRPIMPIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">
Make sure you wire the fan switch with a relay and in-line fuse (if you do it) </TD></TR></TABLE>
If you do it like this then do the fan switch. If your goign to do a fan switch where its switch to batt to fan then dont, because a 2 year old could do that.
I would like to see this External Coil out of the 2.
