What would cause a worn control arm bushing???
Old 06-29-2006, 06:27 AM
viper1984's Avatar
Default What would cause a worn control arm bushing???
I know it could be almost anything...... what would cause a front lower control arm bushing to wear on my arm and not the other??I replaced the arms with newer bushings in them and had an alignment done, and still wearing. I know it could be alot of things but i am trying to find out what could be the cause of it.... if anyone has any ideas that would be great. thanks
Old 06-29-2006, 07:08 AM
savinGAShaulinAss's Avatar
Default Re: What would cause a worn control arm bushing??? (viper1984)
bump for this thread i got the same prob. and would like to know before i replace it for the 5th time.
Old 06-29-2006, 09:10 AM
instructor74's Avatar
Default Re: What would cause a worn control arm bushing??? (savinGAShaulinAss)
check for bent parts lca, upper control arm leaky or worn shocks. Check all your ball joints and tie rods for play. Ask the shop that did the alignment to give you a print out of the alignment specs before, after, and factory spec. I only ever had one lca bushing fail I then put in full polly kit never lost another one.
Old 06-29-2006, 09:15 AM
Suck my DX's Avatar
Default Re: What would cause a worn control arm bushing??? (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">check for bent parts.</TD></TR></TABLE>
Old 06-29-2006, 10:33 AM
Relic1's Avatar
it could also be that your car was in an accident prior to you owning it and they replaced one of the control arms.
but yah, check for bent parts.
Old 06-29-2006, 02:02 PM
thisisntjared's Avatar
where the bolts and/or nuts torqued while the car was on the ground? or while the suspension extended?
Old 06-29-2006, 02:07 PM
Slamaccord's Avatar
Default Re: (thisisntjared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thisisntjared &raquo;</TD></TR><TR><TD CLASS="quote">where the bolts and/or nuts torqued while the car was on the ground? or while the suspension extended?</TD></TR></TABLE>
Good thing you brought this up. Your civic LCA bolts should be tighten at road height.
You see when you torque down the bolts with the wheels hanging in the air, you will notice.
As soon as you put weight on the lca, it straighten's out cause the ruber bushing to stretch.
You must remember rubber dry rots. It will wear due to the weather and road conditions.
Old 06-29-2006, 02:27 PM
Suck my DX's Avatar
Default Re: (Slamaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamaccord &raquo;</TD></TR><TR><TD CLASS="quote">
You must remember rubber dry rots. It will wear due to the weather and road conditions.</TD></TR></TABLE>
i tightened my bolts while the car was up in the air...should i loosen and retighten them at ride height?
Old 06-29-2006, 03:20 PM
Relic1's Avatar
Default Re: (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">
i tightened my bolts while the car was up in the air...should i loosen and retighten them at ride height?</TD></TR></TABLE>
yes
Old 06-29-2006, 09:35 PM
viper1984's Avatar
hey.... well I just replaced the shocks yesterday.... the car was in an accident but the bushing that is wearing is on the opposite side. I did tighten my bolts when the car was in the air.The odd thing is the other side did not wear at all.....I will look into it more, thanks for all the info everyone.... anyone else have anymore ideas please let me know. thanks
sshiny007
20
10-28-2009 06:49 AM
wlee112
28
06-25-2007 08:08 PM
stevescivic
06-21-2007 07:48 AM
94vtirozguy
04-14-2006 11:37 PM
markwitdada9
01-31-2006 05:15 PM
Quick Reply: What would cause a worn control arm bushing???
