what to use on my studs for antiseize?
Just got some kyokugens,
and i'm wondering what you guys use for anti seize stuff?
Can I just use some pb blaster, or do I have to buy a specific product?
Sorry if this is a nooby Q
Re: what to use on my studs for antiseize? (miahmouse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse »</TD></TR><TR><TD CLASS="quote">
antiseize = antiseize
theres a little can with a screw top that has a brush on it i cant remember what its called but its white with some orange on the label and a silver cap
Re: what to use on my studs for antiseize? (93vxhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93vxhatch »</TD></TR><TR><TD CLASS="quote">hay man you want the stuff by Permatex</TD></TR></TABLE>
Permatex. Grey tube, white cap. Or was it Blue tube, white cap, grey lube. Either way, Permatex.
ok, so sounds like the permatex is the good ish,
who carries it?
And so PB blaster is anti seize, is it cool to use that instead of the permatex? i'd prefer that as I already have the pb and wont have to go out and spent money and time/gas
thanks!
who carries it?
thanks!
Re: what to use on my studs for antiseize? (EkDave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkDave »</TD></TR><TR><TD CLASS="quote">Permatex. Grey tube, white cap. Or was it Blue tube, white cap, grey lube. Either way, Permatex. </TD></TR></TABLE>
I use the grey tube... works wonders.
Darth ModerVader
Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">ok, so sounds like the permatex is the good ish,
who carries it?
thanks!</TD></TR></TABLE>
Any auto parts store should have anti-seize compound. Permatex is common, but it doesn't necessarily need to be that brand. And no, PB Blaster is <u>not</u> anti-seize.
who carries it?
All Motor Mentor
1 Post
Re: what to use on my studs for antiseize? (Poopie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Poopie »</TD></TR><TR><TD CLASS="quote">My brakes squeal terribly and I was told to use anti-seize. Where do I apply it? </TD></TR></TABLE>
The only place you would ever use that on your brakes is your caliper slider bolts..
Re: what to use on my studs for antiseize? (00Red_SiR)
Use some Permatex Anti-Seize. Works great on lugnuts, spark plugs, etc.
PB Blaster is great but it's a penetrant, not an anti-seize product.
Re: what to use on my studs for antiseize? (boomslang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boomslang »</TD></TR><TR><TD CLASS="quote">Use some Permatex Anti-Seize. Works great on lugnuts, spark plugs, etc.
PB Blaster is great but it's a penetrant, not an anti-seize product.</TD></TR></TABLE>
gotcha
gotcha
You probably mean anti-squeal spray. You spray it on the BACK of your pads before you install them and it keeps some of the small vibrations down which tend to cause some bit of squeal.
SRd240sx
07-31-2006 12:38 AM
