What type of Bolt-In exhaust do I need
Location: With my POS D15B2, Whereever whenever, United States
Looking to spend 300-400
I have a B16a2 with oem jdm type r header
What straight pipe or cat would I need for a bolt in exhaust into an EG.
I am confused because I can't get a 2.5 inch cat and also if I buy a straight pipe for 2.5, what exhaust would I need to be able to bolt in the exhaust without doing any welding.
Re: What type of Bolt-In exhaust do I need (MugenHonda)
you can buy any exhaust as long as it is made for the EG chassis. If you go for a test pipe i'd recommend the Omni, its adjustable for USDM/JDM headers afaik.
Re: What type of Bolt-In exhaust do I need (Mohsin)
I agree with what Mohsin Said. I also used a testpipe from http://www.testpipe.com awhile ago on my EG Coupe. Either or will work, but I suggest going with the OMNI
If your going the test pipe route check this out:
http://www.omnipowerusa.com/Pr...e.asp
They can be used with a JDM 2.5" Header.
Have a look at Kteller, dont forget to buy the JDM Spec Omni Test pipe.
Re: (Mohsin)
I stay away from K teller, whats the point of paying for clamps or paying more to weld.
Re: (Mohsin)
My question had to do with the exhaust in general including test pipe.
U said k teller and I assumed you meant his exhaust, which I wouldn't buy for that matter, that is comes with no flange and has to be welded, most of the case.
Another_Si_Guy
11
12-07-2015 08:44 AM
markpaco
08-03-2015 02:09 PM
93gsrcoupe
04-13-2006 10:29 PM
Wolfwood
07-25-2005 08:32 AM
