what tranny
what tranny
I'm in need of new synchros in 2nd and 5th gears in my gsr tranny. I'm gonna just put a new tranny in. Which one should I use? I'm gonna take the car to the track so keep that in mind. Also keep in mind that cost is a big issue, I'm married with 2 kids so money doesn't just jump out at me.
Modified by sillvercivicgsr at 9:31 AM 1/18/2004
Re: what tranny (sillvercivicgsr)
Common sense tells you the Type-R then B16 followed by GSR. But since money is always a factor, find the best one you can for what your money allows.
are you staying n/a or going boost? if n/a and moey allows then get the type-r. otherwise get the si tranny....... on the other hand, if cost is a factor, get the gsr and save on gas money. the gsr is also better if you decide to boost the motor.
Re: what tranny (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">Common sense tells you the Type-R then B16 followed by GSR. But since money is always a factor, find the best one you can for what your money allows. </TD></TR></TABLE>
sounds good to me......something that has LSD if you can afford it would be good too!
Re: what tranny (BADEG6)
im going to go with the b16 tranny. it has short gears, and you can put a helical LSD in whenever you have time/money
Re: what tranny (SLeePeR012)
type r if money allows. then b16 is next best for gearing but the b16's are a weaker tranny. the syncros and the diff are the weaker than the gsr/type r.
for boost, the gsr tranny will be best.
EK SQUAD 425
16
08-01-2006 01:20 PM
bboylito
10-30-2004 02:34 PM
