What is this thing ?
1 Attachment(s)
this is my first carburetor engine so i need help from a anybody who can verify this engine parts, since the previous owner has converted mix and match the the engine with unknown parts:thud:
Re: What is this thing ?
1 Attachment(s)
is the wrong question, what i wanted to ask is, is it my electric fuel pump? how to use back the old pump ? tmrw i will snap more photos of the electric fuel pump wiring.
i know those two thing are similar function right? just wanted to know which one better? the electric fuel pump is ok but it makes knocking noise when it feed on petrol to the carb,
nobody knows this? if i do an injection swap do i need to remove this thing? the original fuel pump?:thud:
Originally Posted by vtectouge
(Post 40825070)
kevin |
The first thing that you asked if it was a relay is an in-line fuel filter. The second picture shows the fuel pump. I wouldn't try switching carburated to fuel injected. Better to just get a new motor.
Originally Posted by delsolproblems
(Post 40842713)
(Post 40847662)
what buying a new motor? wow im not rich dude, converting a carb to injection will have big problems? such as?:thud:
what is the car we are looking at year, model, trim etc? i would have to agree a swap will likely be much easier by the time you buy manifold, injectors, fuel rail, sensors, ecu, wiring harness, throttle body... the list goes on. I don't know how hard it is to find an engine in malaysia. But in the U.S. i could pretty much say for certain swapping would be much cheaper.
(Post 40847662)
that second thing looks like it might be the fuel pressure regulator take a better pic of the whole the engine compartment
First pic is either an inline fuel filter or an inline fuel pump, I can't tell for sure if that wire goes into it or not. (just in case no one has ever seen one, there are inline fuel pumps out there that look pretty much exactly like an inline fuel filter with 2 wires coming out the side, they're mostly used on diesels)
You gotta do a looooot to convert it.
New gas lines, wiring, parts that other have stated etc |
Converting to Fuel injection would be JUST as difficult on a new motor....
Putting in a new motor you gotta do the same shit as well as pull the motor and put the new one in. To convert to MPFI you're gonna need to ditch the vacuum advance distributor. And either modify a DPFI (DX, STD) dizzy or buy an MPFI (SI, HF, LX) dizzy with the Cylinder position sensor...and get a DPFI engine bay harness and modify it for DPFI. Then it's the standard MPFI swap stuff. Manifold, TB, Fuel rain, Injectors, resistor box...all should be found in an MPFI swap thread. Don't forget MPFI spec fuel pump....Fuel lines should be similar. |
Originally Posted by joelmatt89
(Post 40848256)
Originally Posted by Eighty-Nyne
(Post 40848488)
Originally Posted by shogee
(Post 40848360)
(Post 40848256)
first pic is a fuel filter second pic is fuel pressure regulator
(Post 40848256)
or the easiest way is buy a car with b16a or b16b in the engine bay huhu |
(Post 40851169)
in malaysia is cheap for D series, its around usd250 or less :thumbup: for complete engine of course, here in malaysia they crave for B and K series only not much D tuner here..:thud:
I can guarantee you that you will pay more to convert to injection, than a swap. And it will be much more work than a swap, listen to people who are trying to help you. |
2 Attachment(s)
(Post 40856028)
well what i was saying is it will be much cheaper just to swap an entire fuel injected engine in. I just said d because it looks like that's what you have. I still don't understand why you haven't listed what your setup/car is.
3 Attachment(s)
here some more:thud:
totally this is the worst eg i had, the engine bay like crap, the under dash board wiring loom sucks big time, this time i need a wire man to assist me with this project, because im a wiring noob :thud:, will update you guys with the transplant very soon
wow... thats some nasty wiring going on there
