what are these littlel metal cylinders?
RTFM
we took a jg d16z6 head in to be hot tanked and those fell out. the head was the casting, valves, rocker arms and caps...no sensors, no vtec solenoid on it, no cam.
the actual size is very close to the size of a brand new eraser on a #2 pencil....
any ideas? i really dont want to tear down another had to find them....
thanks
Re: what are these littlel metal cylinders? (v4lu3s)
they're called dowel pins i think. they fell out when i pulled my head too. they go on the bottom, where it mates with the block...not really sure what its purpose is, but im sure its pretty important.
**Edit**
i read that it helps with alignment...
**Edit**
Re: what are these littlel metal cylinders? (Racerage1)
i dont believe those are dowel pins (dowels are hollow). these look like the things that go on the rocker arms... i have no way of describing nor do i remember EXACTLY where they went, but they look like rocker arm pieces.... gotta find a pic to show the location...
Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">are dowel pins really that short? those are about 5-7mm tall.</TD></TR></TABLE>
VTEC PISTONS!!! Don't loose them!!!! They go in your rocker arms and slipped out when you took them assembly off and hte rockers were allowed to shift.
You loose those, you have to buy a whole new 100 dollar rocker assembly!
RTFM
alrighty. i had my friend tape them up together and right now we actually left them in a cylinder on top of the piston since the head wont go on til i put them back where they belong.
thanks!
thanks!
Re: (v4lu3s)
Yes those peiecs are part of the lost mation assembly.
They hold the VTEC Rocker arm assembly to the other Two intake rockers. ( on a D-Series.)
HTH
Brian
HTH
Brian
Re: (TurbodCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurbodCX »</TD></TR><TR><TD CLASS="quote">Yes those peiecs are part of the lost mation assembly.
HTH
Brian</TD></TR></TABLE>
those are not part of the LMAs, the LMAs are one piece that sit under the mid rocker arm, its just a cylinder with a spring in it to keep pressure on the mid rocker arm and to keep them from flying up and down when they aren't locked to the outer rocker arms.
HTH
Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx »</TD></TR><TR><TD CLASS="quote">
those are not part of the LMAs, the LMAs are one piece that sit under the mid rocker arm, its just a cylinder with a spring in it to keep pressure on the mid rocker arm and to keep them from flying up and down when they aren't locked to the outer rocker arms. </TD></TR></TABLE>
OOps. I always considered that part of the LMA's Thanks for the coreection bro
Brian
Brian
Re: (USDM Tsuchiya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM Tsuchiya »</TD></TR><TR><TD CLASS="quote">haha, it took 7 posts to show him that they are vtec pins... haha
..shows alot abooot the EG+ civic /del slow forum </TD></TR></TABLE>
thanks for chiming in!
5thgen
15
09-17-2003 07:56 PM
