What should I expect from my D16?
Hey guys,
Just curious to see what kind of results I should expect from my engine build.
I'm sure someone in here is running similar components and would like to see what you guys are running at the track and dyno. Here's a list of the internals, etc.:
D16y8 block, head and intake manifold.
Zex stage 2 cam, with Comp springs.
Factory crank.
Eagle H-beams.
ACL bearings.
JE SRP pistons w/ 10.5:1 comp. and a 2.972 bore dish (20 over ).
MSD 6a, Blaster coil, and 8mm wires.
A/I & Filter.
Hayame exhaust
B&M fuel reg.
55 hp shot of Zex NOS.
Lemme know whatcha think....
Thanks.
Factory crank.
Eagle H-beams.
ACL bearings.
A/I & Filter.
Hayame exhaust
B&M fuel reg.
Thanks.
Re: What should I expect from my D16? (dimotorsports)
i built a 95 d16z6, last year! it's running stock bottom end, and valve train, in a '92 civic hatch, it's beatin 99-00 SI's. I've had the car dyno'd at 155 whp! So i would expect 180hp or in that range somewhere out of your motor!
Re: What should I expect from my D16? (hondatuner99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner99 »</TD></TR><TR><TD CLASS="quote">i built a 95 d16z6, last year! it's running stock bottom end, and valve train, in a '92 civic hatch, it's beatin 99-00 SI's. I've had the car dyno'd at 155 whp! So i would expect 180hp or in that range somewhere out of your motor! </TD></TR></TABLE>
what the hell are you talkin about? you BUILT a d16Z6 and its running stock bottom end and valve train?? what the hell did you build it on HOPE and DREAMS!!!
Risky Business
This is the biggest load of **** ever. First of all a "built" motor has aftermarket pistons and valvetrain. Second...I HIGHLY doubt your car dyno'd at 155WHP. With stock compression on a D16Z6 that is almost impossible. And you should be beating 99-00 Si's stock...they aren't fast unless Mr. Milano or v00tecsi is driving. You will be NOWHERE in the 180hp range NA. With the 55 shot, I dont know. Ryancivic2000 ran a 75 shot on a stock D16Y8 w/ bolt ons and got 181 WHP...so maybe that will give you an idea.
Re: What should I expect from my D16? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">750 WHP
8.7@160
bwuahahahahaahaha!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy »</TD></TR><TR><TD CLASS="quote">
what the hell are you talkin about? you BUILT a d16Z6 and its running stock bottom end and valve train?? what the hell did you build it on HOPE and DREAMS!!!</TD></TR></TABLE>
bwuahahaha again!
8.7@160
bwuahahahahaahaha!
bwuahahaha again!
Pooping on children
bwuahahahahahahahaahahhahahahahaahah
you are the king of fucktardery
Global Moderator
8.7@160
Seriously...it is impossible to determine HP and 1/4 mile numbers based on a list of mods</TD></TR></TABLE>
Very True!
Also search
8.7@160
Very True!
Also search
brusk13
06-20-2005 09:25 PM
