What should I do to a B16 Hatch?
I am getting a Honda hatchback most likely a 93-95 and I am going to do a b16 swap in it! What are some things I should put on it I do not want naturally aspirated. I am thinking turbo tell me what else I can do to it.
Re: What should I do to a B16 Hatch? (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">first thing i would do to your car is SEARCH</TD></TR></TABLE>
good thinking, i wish the noob could of thought about it first.
Re: What should I do to a B16 Hatch? (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">and the 05 members start off right where the 04 members left off....... </TD></TR></TABLE>
Research this, some would go all motor, others FI. Its all what you want from the car. Daily driver, track car, drag monster, etc
Re: What should I do to a B16 Hatch? (teknoracing)
instead of doing something to the b16 why don't you just get a b18c (type R) engine. It'll be just as fast as a modified b16 if not faster and it will have more torque and have the good old honda reliability.
Re: What should I do to a B16 Hatch? (zman)
here this will help
https://honda-tech.com/zerothread?id=979961
Location: hittin corners so hard you can taste my rims..
Re: What should I do to a B16 Hatch? (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">here this will help
https://honda-tech.com/zerothread?id=979961</TD></TR></TABLE>
Re: What should I do to a B16 Hatch? (Built B16A)
Man.....why do I live in Louisville?!?!
Search bro...might want to read the rules too.
Just turbo your d series that will be in it. You can piece together something really cheap. Go to amens (spelling) off bluelick road. its a salvage yard. Go to the honda crx's and grab you a HX manifold off there. 50$ but you gotta take it off. Then just get an adapter plate and a RHB5 off a mazda or probe....dirt cheap. i mean you still have fmu and IC pipes and other little things....but it's fairly cheap. go to http://www.homemadeturbo.com
It has a few writeups.
Re: What should I do to a B16 Hatch? (murmur9)
defintely turbo your d-series. unless you buy an si and in that case you start out with a B16. anyways, buy a block saver, take it to a machine shop and get it welded in and the block and head milled, then go check on ebay for d-series turbo mainfolds and kits or just buy a d-series kit from turbonetics or APEX'i. Oh and while your getting the machine work done throw in new forged interals, and replace the valve springs and cam. replace the various fuel items and then run like 14 psi of boost. that should be like 300hp, from a single cam. but seriously, build a d-series.
E.Honda
24
05-21-2007 02:39 PM
