What psi can i run for my setup?
Im rebuilding my engine next weekend after i blew my piston rings! its a d16z6
Its got crower stage 2 cams springs and retainers
eagle rods
vitara pistons, npr rings, acl bearings
apr head bolts
cosmetic gasget 3 layer
going to be tuned on crome
440cc RC injectors
2.5 bar motorola map
considering all this what psi will be best?
Also i had a problem with it overheating before, ive got a large ali racing radiator now, will that fix the problem? Thanks
eagle rods
apr head bolts
440cc RC injectors
Re: What psi can i run for my setup? (civic_turbo_wannabe)
your over heating was prob exhaust gas getting into the coolent system. that 3 layer fixed that i bet.
Have a d16y8 in my driveway (not mine) running 14-17 psi on all stock internals. depending on when the wastegate isnt stuck, junk yard failure!
3layer w/ arp
440s
crome
225l
its still running, been 6 months now.
im sure others have better input, however, id say 20-22psi easy. what turbo are you using? need more info
3layer w/ arp
440s
crome
225l
log manifold, cast iron
T3 knock off turbo (but works very well and holds psi steady with external w/g)
big 3 n half inch plus downpipe with 2 n half inch exhaust, without decat
walbro uprated fuel pump
u think 20psi? i dont wanna over do it... again!
Re: (civic_turbo_wannabe)
yea thats nice compression for a good turbo setup i would say start out around 14 psi and see how it goes. 20 seems kinda extreme if you are daily drivering this car i wouldnt go over 15psi.
Re: (STDClayton)
PSI IS COMPLETELY IRRELEVANT WHEN BOOSTING A MOTOR... YOUR MOTOR FAILS BECAUSE OF HP NOT PSI OF BOOST! sorry for the caps but i'm sick and tired of seeing people post these stupid "how much psi can i run" threads.
idk about boost level because of the setup But if you plan to go above 10 i would STRONGLY STRONGLY Reccomend a set of ARP Rod bolts.... that will make your rods hold stronger/. but yet thats just my 2Cents
Re: (Civic9390)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic9390 »</TD></TR><TR><TD CLASS="quote">idk about boost level because of the setup But if you plan to go above 10 i would STRONGLY STRONGLY Reccomend a set of ARP Rod bolts.... that will make your rods hold stronger/. but yet thats just my 2Cents</TD></TR></TABLE>
i didnt studder... psi is not what breaks rod bolts!!! power made by the motor is what breaks rod bolts... i can take a tiny *** 14b turbo and put 10 psi to a gsr and it will make maybe 210whp... MAYBE! i can take a borgwarner s372 on 10 psi and scatter that damn motor all over the place because its making over 3-400
well ive got arp head bolts and eagle rods are in now with ycp pistons 8.5:1 npr rings... so if i tell my tuner to boost to 20 psi... is that fine? bare in mind i have a 2.5 bar motorola map and 440cc injectors... what do you guys recommend? ... i am trying to learn... dont rip into me.... does not help one bit
not tryin to rip you man but psi is irrelevant without a turbo size... like i said a 14b on 20 psi you can drive all day... a borg warner s372 or s366 or somethin (pretty big turbo's) on 20 psi will scatter that built motor everywhere
Re: (94c1v1cex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex »</TD></TR><TR><TD CLASS="quote">not tryin to rip you man but psi is irrelevant without a turbo size... like i said a 14b on 20 psi you can drive all day... a borg warner s372 or s366 or somethin (pretty big turbo's) on 20 psi will scatter that built motor everywhere</TD></TR></TABLE>He's right remember its about how much pressure the turbo builds at once not that you can get 20psi but small turbo build up gradually. Other larger turbos boost more instantly. We all know it as turbo lag or boost creep. Besides if your going to tune it the tuner should be the one telling you what would be a safe level for you but I have seen single cams running on stand alone ECU with stock internals go as high as 25psi with a t60-1. It lasted 3 months before it went but it was good for a 12 second pass on the track. (he had 780cc injectors and a OLDER Haltech But he was his own tuner)
Re: (slvrcvc93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrcvc93 »</TD></TR><TR><TD CLASS="quote">He's right remember its about how much pressure the turbo builds at once not that you can get 20psi but small turbo build up gradually. Other larger turbos boost more instantly. We all know it as turbo lag or boost creep. Besides if your going to tune it the tuner should be the one telling you what would be a safe level for you but I have seen single cams running on stand alone ECU with stock internals go as high as 25psi with a t60-1. It lasted 3 months before it went but it was good for a 12 second pass on the track. (he had 780cc injectors and a OLDER Haltech But he was his own tuner) </TD></TR></TABLE>
you kinda got the jist of it. its not how fast the turbo spools... because the smaller turbo will boost more instantly, the bigger turbo as you said has lag which makes the boost come on slower.
its just the ammount of air that is moved by the bigger turbo than the smaller one that makes more power. like i said its power that hurts your motor not boost. we cant tell you how much boost to run unless you give us a complete engine setup and a turbo size... even then its not always the stereotype of what we may say... its what the motor likes. you will learn that. i drive cars all day long that are being tuned
Re: (94c1v1cex)
LOL <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex »</TD></TR><TR><TD CLASS="quote">15-17 psi from a tiny dsm turbo would be fine... you people dont see the point i give up</TD></TR></TABLE>
I was reading this thread and I was about to tell you to give up hahaha
Re: (.Grimace)
like he said above you dont have to worry about your boost levels anyway if you go to a good tuner. Hes gonna tell you whats safe and whats what when you tune.
Re: (00b20vtecoupe)
you should read alot about tuning http://forum.pgmfi.org/ dont just jump into 15psi start out low 6psi 8psi and tune your way up. get a wideband if you dont have one. http://14point7.com/Widebands/...1.htm has a good cheap one for a diy guy like your self it also datalogs love it.
learn to read plugs http://www.dragstuff.com/techa....html
make sure you look at all the links on the bottom.
i think this is info you want us to tell you.
Modified by ashb82 at 1:00 PM 9/20/2008
