what is the process to convert non Vtec in to Vtec
Re: what is the process to convert non Vtec in to Vtec (djjosehernandez)
It's probably not worth the effort unless you are doing an LS/VTECH swap.
Here are two posts explaining a mini-me swap, both write-ups were in the FAQ section.
https://honda-tech.com/zerothread/2147115
https://honda-tech.com/zerothread?id=554053
Modified by mechanix619 at 11:42 PM 4/15/2008
basically throwing a vtec head on to a non vtec block. Its not a job for a noob but it can be done and if done right (depending the motor application) you will see some good #'s.
Modified by bmoua at 11:46 PM 4/15/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djjosehernandez »</TD></TR><TR><TD CLASS="quote">about how much do they run for ???</TD></TR></TABLE>
Depends how cheap you can get the parts for and who is doing the labor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djjosehernandez »</TD></TR><TR><TD CLASS="quote">whats the process on it ????</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djjosehernandez »</TD></TR><TR><TD CLASS="quote">what are the parts needed</TD></TR></TABLE>
Did you read the links I provided?
The two gentlemen that wrote up the DIY's pretty much explained everything you need to know.
the links for the process and what you would need is already given to you. use it.
l Love JDM
23
01-29-2012 08:49 AM
big bentley
04-11-2002 07:21 AM
