What parts make up the "catalyst system"?
Besides the obvious "catalytic converter", and I'm told "PCV Valve" as well (???)... anything else?
Car is a 00 Si...
Car is a 00 Si...
Re: What parts make up the "catalyst system"? (JoshuaVTEC)
I don't know for sure, but I think it would include the air box, intake arm, intake manifold, exhaust manifold, the cat, and all the sensors hooked up to it.
try changing your catalytic converter. I had a code 67 a malfunctioning catalyst system. I changed the cat and the check engine light went off. I got a magnaflow high flow cat for 100 installed. they even made a bung for my 02 sensor.try it.Good luck.
that code can also mean a misfire, first i would go on the highway or run it hard to try and clean it out and if it doesnt go away give it a tune up if it needs it. if you gave it one recently then change the cat out
elpiar
05-08-2005 09:37 AM
