What oil should I be running in my CRVtec engine?
I just picked up a 92 hatch with a crvtec swap in it. I was just wondering what weight oil I should be running in this engine. I'm guessing mobil1 5w30 is gonna be the right stuff, but figured I'd bounce it off you guys and see what the consensus is. I tried the search feature but couldn't figure out what terms to use to get the answer I'm looking for.
TIA
TIA
Re: (97spooncivic)
this is true about synthetic to conventional. also were any internals replaced on the engine. if so it might depend on which oil you want to use for viscosity
It's a stock b20b bottom end with a b16a head. Only internal part swapped was a set of CTR cams... I'm just gonna go with the Mobil1 5w30 and hope for the best...
hondacivic4g
07-11-2002 10:14 AM
