what oil pan for d16y8 and boost? i need help
ok so i bought a d16y8 off a shop that had a bad bearing, i pulled the oil pan and taped it for my oil return and brazed in my fitting. today when i go to swap it with the y8 in my car their nothing alike. and theirs no hole for the dipstic. so their oil pan is not from a y8 and prolly a d15 dx engine.
will this pan still work? can i just drill the hole for the dipstic and be ok?
help me out guys.
help me out guys.
at the jetties fishin'
Re: what oil pan for d16y8 and boost? i need help (bmcc72)
y8 uses an aluminum pan that won't fit any other d engine. You need to either tap your pan or find another aluminum pan.
I got an extra off ebay used for $50 when I was doing my turbo kit.
Re: what oil pan for d16y8 and boost? i need help (stackz)
is their any way to modiy the z6 or d15 to fit or work? also i heard the 96 had a metal pan. can anyone verify?
Modified by bmcc72 at 1:23 PM 7/9/2004
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I got a D16Z6 oil pan to fit on my boosted D16Y8. Had to drill out two holes a bit more but it fit.
Kinda leaking though.
Guest
Posts: n/a
Re: what oil pan for d16y8 and boost? i need help (boostincoupe)
Y7 pan also fits on the y8 and vice versa. I kow this cause I have a y8 AL. pan on my y7. Other than that the older pans won't work cause the the oil pump bolts are different I believe
what did u drill out? also did u drill the whole in the baffle for the dip stick? and at full does it use the same amount of oil as the stock y8 pan?
