WHAT MOTOR MOUNTS???????????
I've got a 1992 civic dx that i'm swapping a 93 ex (d16z6) motor into. Now do I need to use the mounts that came in my 92 or use the ones out of the 93 ex? They all look the same except for the driver side top mount. The 93 mount looks alittle different. THANKS 4 YOUR HELP!
Re: WHAT MOTOR MOUNTS??????????? (1slow4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwieczorek43 »</TD></TR><TR><TD CLASS="quote">I believe you use the z6 mounts</TD></TR></TABLE>
yea all of them are the same except for the drivers side cause the z6 motor has a diffrent bracket on the motor where the mount bolts into
Re: WHAT MOTOR MOUNTS??????????? (slambedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic »</TD></TR><TR><TD CLASS="quote">no they arent.... you NEED to use the EX/Si driverside mount.</TD></TR></TABLE>
cool, im using my stock lx mounts on my z6 swap
Re: WHAT MOTOR MOUNTS??????????? (Timmay)
if its a 5th gen, its not possible unless you changed out the motor side bracket... i too have a 5th gen LX with a Z6 swap in it....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slow4door »</TD></TR><TR><TD CLASS="quote">So use the driver side ex mount? All the rest are ok?</TD></TR></TABLE>
correct
correct
Knightmare69
05-05-2004 08:00 PM
crex23
10-11-2003 06:02 PM
