What is a missing link?
Re: What is a missing link? (trooper0641)
if you are using an fmu, then ya. it goes between your IM and the map sensor. prevents it from "seeing" pressure and throw a code
edit: if you are getting a greddy kit, then no, you use the blue box that it comes with
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote">What is a missing link? Is this peice needed for my turbo setup?</TD></TR></TABLE>
No, search around, you can make a check valve that eliminates the need for one. If you want it to look clean, then get one i guess.
Re: What is a missing link? (wowsers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wowsers »</TD></TR><TR><TD CLASS="quote">if you are using an fmu, then ya. it goes between your IM and the map sensor. prevents it from "seeing" pressure and throw a code
edit: if you are getting a greddy kit, then no, you use the blue box that it comes with</TD></TR></TABLE>
Going to be running the vortech fmu for a while...i guess the missing link is needed. Does it just go right in? Or do i have to do some cutting?
if the fmu is a temp setup, you can make you own check valve, ghetto missing link, with some 1 way valves avaliable at your local pet store in the aquarium section. search ht, its probably been posted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wowsers »</TD></TR><TR><TD CLASS="quote">if the fmu is a temp setup, you can make you own check valve, ghetto missing link, with some 1 way valves avaliable at your local pet store in the aquarium section. search ht, its probably been posted.</TD></TR></TABLE>
LOL im poor but im not ghetto... ;] thanks for your advice
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote">LOL im poor but im not ghetto... ;] thanks for your advice</TD></TR></TABLE>
Umm... that is hardly being ghetto...
as long as it works, its cool.
check valves, hoses and ends, couple of bucks.
missing link $40-50
i would just use check valves becuase you only plan to use the fmu temp. you need several though.
missing link $40-50
haha. i actually tried using three check valves in place of a missing link. gooped the t connections to the port on the throttle body, some vacuum line connecting it.
lets just say it didn't work too good.
BIGblock97
08-25-2005 10:30 PM
