what manual tranny will fit a 1998 civic..?
Old 12-03-2008, 10:23 AM
lexluther's Avatar
Default what manual tranny will fit a 1998 civic..?
Hey, just wondering what will interchange, not looking to "trick it out", just replace the factory broke one. will a 1990 fit? it matches right up to the block but will it work, the 1998 is an LX.. non-VTec i think. Thanks
Old 12-03-2008, 10:28 AM
hazard2o9's Avatar
1990 tranny wont work because its a cable tranny and your civic is a hydrolic tranny, any d series tranny from 92-00 should work for your car
Old 12-03-2008, 10:47 AM
blink_977's Avatar
you need S40 tranny from 96-00, at least S20 from 92-95.
Old 12-03-2008, 11:12 AM
lexluther's Avatar
So a 92-95 wont work? or will work?.. i am confused..
Old 12-03-2008, 11:33 AM
burningrex's Avatar
92-95 will work also 96-00... both hydrolic...
either one...
Old 12-03-2008, 06:47 PM
lexluther's Avatar
ok, still a bit confused here, one guy says 96-00, and a couple others say 92-00.. will 92-95 work or no? thanks
Old 12-03-2008, 06:48 PM
nix94delsol's Avatar
92-00 will work, since they're all hydraulic and for D series.
Old 12-03-2008, 09:38 PM
lexluther's Avatar
Awesome thanks!
Old 12-03-2008, 09:43 PM
kojack_0's Avatar
yup all 92-00 single cam/d-series HYDRO transmission will fit in your car.
but im not sure if the 92-95 civic axles are the same with the 96-00 civic axles.
Old 12-03-2008, 10:16 PM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Axles are the same. Trans will bolt up and work just fine.
92-00 civic D series axles and transmissions are 200% interchangable. That's 100% more than 100%.
If you get a 92-95 trans, just take the brackets and stuff off your 96-00 trans so that the clutch lines will have their brackets. EEEEEEEEEEEVERYthing else is the same.
The 88-91 will work as well...but you'd have to get an expensive hydro to cable converter.
Old 12-04-2008, 11:17 AM
lexluther's Avatar
Cool, I havent pulled this tranny, it come with a bad tranny, the guy said it just lost gears wile driving, and all it has now is 1st and reverse...
Old 12-04-2008, 12:05 PM
B serious's Avatar
That's all you need. 1st on that car probably goes up to like 40 or 45. Why do you want to go faster? Slow down, you maniac.
Reverse is nice. There's starving kids in 3rd world countries that can't even walk backwards.
I'd say leave it. Stop living a life of decadence.
Seriously, though....I used to drive around in 1st gear on main roads with beaters all the time.
Old 12-04-2008, 07:00 PM
lexluther's Avatar
I had an auto that wouldnt shift out of 1st once, they dont get very good mileage that way, and riding mower may smoke you!..
Old 12-04-2008, 07:49 PM
rsnupt82's Avatar
uh... the 90 has to be hydraulic.. if not, u have to go on a mission converting it to hydraulic with one of them fancy kits. if its auto... u need pedals, pumps, and a whola lotta ****.
Old 12-04-2008, 08:58 PM
lexluther's Avatar
Na, its a manual, its just bad, i havent checked it out yet i bought the car broke, and its missing all gears except 1st and reverse.. it would be nice if it was a simple fix.. anyway i will be putting back a manual, just wanting to know what my interchange options were, i think this 98 is hydraulic, but i do know the 90 is cable... i think ill try to find a 92 and up, i dont really want to 'convert' it.
Old 12-11-2008, 03:17 PM
lexluther's Avatar
Does anybody know where i can find a schematic for my tranny? 1st and reverse work just fine, but no 2nd, third, fourth or fifth.. the tranny doesnt clank or anything.. i think its just a shift fork problem.
Old 12-11-2008, 04:09 PM
batallic's Avatar
92-00 trannys are interchageable manual to manual, auto to to
Old 12-11-2008, 04:27 PM
lexluther's Avatar
I know, thanks to some of the guys earlier in the thread, but is mine worth fixing? it may be an easy fix if i had a schematic.
Old 12-11-2008, 06:13 PM
batallic's Avatar
u can pick up a tranny for like 150,
Old 12-11-2008, 06:48 PM
lexluther's Avatar
My local wrecking yard wants $325
Old 12-11-2008, 07:02 PM
Seagull Management
94EG8's Avatar
Private sale will be a lot cheaper. DX trannys run anywhere from $50 to $150 used private sale most of the time. Check craigslist.
Old 12-11-2008, 07:25 PM
lexluther's Avatar
cool thanks, my car is an lx, is the the same as dx?
Old 12-11-2008, 08:05 PM
Seagull Management
94EG8's Avatar
Yes. Below i've listed whats what for D-series trannys from '92 - '00, they are listed longest to shortest as far as gearing goes:
1992 - 1995
-CX/VX
-DX/LX
-EX/Si
'96 - '00
-HX
-CX/DX/LX
-EX
Old 12-11-2008, 08:32 PM
lexluther's Avatar
So will a '92 to '95 DX/LX be a close gear match for my '98 LX?
Old 12-11-2008, 08:47 PM
Seagull Management
94EG8's Avatar
Yes, Identical actually.
Quick Reply: what manual tranny will fit a 1998 civic..?
