what header/exhaust manifold for 96 dx?
stock dx engine has the cat right off of the block. and there are two o2 sensors. i dont feel like looking at a check engine light. any headers that house both o2 sensors without having to change the exhaust so a cat. will fit?
and i dont think the lower one will reach to the back of the header where i see most 2nd o2 sensors.
Re: what header/exhaust manifold for 96 dx? (SOHC Beast)
or is there a simple way to cheat the ecu from looking at that 2nd o2 sensor?
There is no aftermarket header that will use both 02 sensors and not throw a code. The reason is the second one is checking to make sure that your cat is functioning properly. You can get a 02 simulator and the CEL won't come on, but I'm not sure how it deals with the 02 sensor heater. Anyone have any more info on this??
Re: what header/exhaust manifold for 96 dx? (Ricey McRicerton)
screw it. its dumb tring to make a slow engine fast anywayz....my friend wants $450 for his 2000 ex swap..... engine, tranny, axels, ecu, blah blah. but i have to take it out...and he said that it would grind real bad in 2nd, but he thinks it is because the rear engine mount is bad. i think it is b/c the tranny is bad.
might be worth the money?
Just get a good EX tranny and do a mini-me swap on the motor you have. I've got a turbo y7 and hit high 13s on street tires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Just get a good EX tranny and do a mini-me swap on the motor you have. I've got a turbo y7 and hit high 13s on street tires. </TD></TR></TABLE>
you have stock y7? or vtec head.. or just y8 IM? what kind of car do you drive? i see you are in NC... not very far from me. ever come into high point or kernersville? i had a red 94 hatch with d16z6 stock boosted at 10psi w/ greddy kit and hondata...and a dsm SMIC. made 200whp and 195wtrq... never made it to the track though . to do a mini me on this.. would cost me as much as buying my friends... might as well buy the whole thing for 450. need a y8 head, timing belt, y8 head gasket, ecu, ex tranny(helps), i am already over what it would cost for my friends stuff. and while it is out, might as well install a better clutch.
i thought about doing a y8 IM swap, a better clutch/tranny... and then home-making a turbo setup. do you know if a HF manifold and a 15g will clear stock a/c?
I'm in NC, but never get over that way man. I've got a y7 block and head with the Y8 intake mani. I don't think the hx mani will fit and keep a/c without an adapter. I've got the 15g kit on my car and love it to death (in a 97 hatch).
hondachick81
06-26-2001 12:12 PM
