what header b16 or b18 for gsr swapped del sol.
i was wondering what header to get that will bolt up to my gsr motor to the cat, so i dont have to do any welding. thanks alot.
Re: what header b16 or b18 for gsr swapped del sol. (yoursupahero09)
i heard (HEARD not even 25% sure) that a b16 ex-mani will fit perfect but i havent seen first hand
I wasn't aware that you need to weld headers for a swap? maybe your engine sits low for some reason?
really unless someone else proves other wise, (or if I'm just misunderstanding the question) the only problem that i know with swaps and exhaust manifolds/headers is that if for some reason your motor sits too high, or too low, you can split/pinch your headers. But if that's the case you'd have to re-mount your motor
B series headers should fit a B series motor on just about any swap. (I haven't seen any other problem except for the one explained above)
It all depends, I just threw a GSR into my Si. I tried to put a 00-01 GSR Header onto it, but it was too short and the flange was at a different location. I believe that the older GSR Header fits without modification
Re: what header b16 or b18 for gsr swapped del sol. (Full-Race Henry)
alright thanks for your input looks like im getting a dc header then
M0nK3e.StyLeZ
15
03-30-2005 07:04 PM
- BSeRiouS -
02-15-2005 01:41 AM
