What harness/wires? D16y7 to B18b1
I own a 1996 Honda Civic LX Sedan with a D16y7 in it rn. I took the B18b1 from my 1994 Acura Integra RS. Im a little iffy on the whole OBD1 and OBD2 stuff, and Im also iffy about what kind of wiring I need done. Ive done some research and I know that theres things like jumpers and what not, but overall i just need to know what I actually need for the wiring, and what OBD anything is and how to convert to what i need. Any help?
Corvette Forum Member
Re: What harness/wires? D16y7 to B18b1
https://honda-tech.com/forums/honda-...-vtec-2987229/
Just my opinion, but I think you should do more research before you dive into a project like this. Just sayin.
Read it, use it, love it.
Seagull Management
Typically you would use the original Y7 harness and modify it. I would suggest swapping the alternator, distributor and injectors out for OBD2 units for the sake of convenience. But you can use the OBD1 stuff and splice the plugs on. You will either need to run the original ECU with a conversion harness or a '96 - '99 LS ECU and do the CKF trick to fool the ECU into thinking the CKF sensor is present and working
