what engine do i have?
looks like an EG4 motor but seems there's no vtec soleniod
http://www.imagestation.com/picture/...4/f3010be4.jpg http://www.imagestation.com/picture/...8/f301120b.jpghttp://www.imagestation.com/picture/...9/f3011205.jpg help me out guys |
non vtec d15b
Re: (jdm951EK4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm951EK4 »</TD></TR><TR><TD CLASS="quote">non vtec d15b</TD></TR></TABLE>
https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (jdm951EK4)
i thought d15b comes with vtec, isn't the d15b an EG4(VTi) motor?
d15b is a jdm motor https://honda-tech.com/forums/images...es/emsmile.gif
could be from alot of models.. the japanese for some reason made different engines and gave them the same engine codes... ie: b18c1 and b18c5 in north america have different internals, different power, but in japan both of them are just called b18c https://honda-tech.com/forums/images...es/emsmile.gif u my friend have a non vtec d15b as everyone else said.. coulda been in more then one car, in more then one year |
Re: (Morning Call)
i dont think so but it is a possibility. at worst, im thinking i got a frankenstein or something
Modified by HmgLauj69 at 11:44 PM 8/1/2005 |
Re: (HmgLauj69)
i think i read once that d15b non vtecs come in some vx hatches??? correct me if i'm wrong https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (Scrapin4DR)
no vx's all have vtec
Re: (93ejay1)
what about cx?
Re: (Scrapin4DR)
lol, how much did you pay for this motor?
Re: (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">no vx's all have vtec</TD></TR></TABLE>
vtec-e https://honda-tech.com/forums/images...s/emsmilep.gif |
Nice looking civic cx motor https://honda-tech.com/forums/images/smilies/emsad.gif
Re: (HmgLauj69)
You have a non VTEC d15b.
D15b4, non-vtec, weaksauce without a turbo.
Re: (Pioneer162)
it's not a d15b4, right now im thinking it's probably as morning call had said. some kind of weird ass civic from japan/germany and such. i found something at hondaswap saying there were at least four types of D15B motors in japan. all of them had vtec/vtec-e except one. but that one that isn't vtec is carb so rules that out. still lost to as knowing what motor i have http://images.honda-tech.com/set1//smile/emcrook.gif
the following are civics that came with D15Bs (from hondaswap) 92-95 Civic VTi, 96-00 Civic Vi, 92-95 Civic ETi, 92-95 Civic MX, 97+ Domani 15E MB3 SOHC D15B vtec-e 94ps@5500/96.9lbs-ft@4500 75.0 X 84.5 1493cc 9.3:1 92-95 Civic ETi SOHC non vtec D15B carbed 100ps@6300/92.5lbs-ft@4500 75.0 X 84.5 1493cc 9.2:1 92-95 Civic MX SOHC D15b vtec 105ps@6400/98.3lbs-ft@4500 1493cc 75.0 x 84.5 9.4:1 97+ Domani 15E MB3 SOHC D15B vtec 130ps@7000/112lbs-ft@5300 3 Stage VTEC+PGM-FI bore x stroke 75.0×84.5 1,493cc, compression = 9.6:1 92-95 Civic VTi 96-00 Civic Vi |
Re: what engine do i have? (HmgLauj69)
Someone ganked your VTEC!!! https://honda-tech.com/forums/images...s/emsmileo.gif Ha ha ha! You have a 1.5L non vtec...
Re: (HmgLauj69)
It's a D15B non-VTEC engine that originally came with a twin carb intake manifold. I know because we get these all the time from an importer to replace US-spec 1992-1995 Civic 1.5L non-VTEC engines. It's as simple as adding the stock US intake manifold, so carb'd or not originally, it works fine fuel-injected as long as you block off the port where the old carb'd distributor used to be.
Good news: It's a 16-valve engine much like the 92-95 DX engine. so in other words it's probably 102hp instead of the shitty-ass 8-valve 70hp CX engine. Bad news: It's only 102hp. https://honda-tech.com/forums/images...s/emsmilep.gif |
Re: (B18C5-EH2)
your saying my motor was originally carb?
Re: (HmgLauj69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HmgLauj69 »</TD></TR><TR><TD CLASS="quote">your saying my motor was originally carb?</TD></TR></TABLE>
Definately. Take some detailed pics of the area near the distributor - if there is a little plate that's almost oval-shaped with two bolts through it and it's sealed with gasket maker, then it was definately originally carb'd. EDIT - I see that plate on your lower right pic, in the lower right corner of the pic. It's definately an originally carb'd engine, because that plate blocks off where the mechanical fuel pump used to be when it was carb'd. Honda had carb'd Civics well through the EG chassis in Japan. Modified by B18C5-EH2 at 4:10 PM 8/2/2005 Modified by B18C5-EH2 at 4:12 PM 8/2/2005 |
Re: (B18C5-EH2)
finally some useful information https://honda-tech.com/forums/images...s/emsmilep.gif
thanks b18c5-eh2 https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">It's a D15B non-VTEC engine that originally came with a twin carb intake manifold. I know because we get these all the time from an importer to replace US-spec 1992-1995 Civic 1.5L non-VTEC engines. It's as simple as adding the stock US intake manifold, so carb'd or not originally, it works fine fuel-injected as long as you block off the port where the old carb'd distributor used to be.
Good news: It's a 16-valve engine much like the 92-95 DX engine. so in other words it's probably 102hp instead of the shitty-ass 8-valve 70hp CX engine. Bad news: It's only 102hp. https://honda-tech.com/forums/images...s/emsmilep.gif </TD></TR></TABLE> B18C5-EH2 is correct. I use to have one of these motors in my EG hatch. It replaced my blown DX motor. And it came with twin carbs and all we did was swap out the intake manifold and dropped right in. You can tell it's non-vtec by looking at the valve cover. Sohc Vtec's have the spark plug holes pointing to the front of the car. While non vtec sohc points to the rear. All I have to say is when I had this motor and I raced my cousins truck. I was being pulled. Now I have z6 and I got to say big diff. |
wo good infor b18c5.... my friend had a d15b non vtec.. and it had the same plate and i thought the same thing that someone jacked the vtec solinoid so i pulled the valvecover to see if it had the extra lobe and it didnt... i was very confused about it for a bit about why it would have the plate there and not the solinoid and no cam
Re: (Pioneer162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pioneer162 »</TD></TR><TR><TD CLASS="quote">D15b4, non-vtec, weaksauce without a turbo.</TD></TR></TABLE>
weaksauce WITH a turbo |
