What engine block should i get?
Hey, so a few weeks back i had a timing belt slip. and crush my number 2 pistons agaist the valves. first of all it was a gsr head ontop a type-r block. So i got a few questions: first of all forget tryn to replace the pistons on the type-r block. to much money. you guys think i can just possibly fix the valve unit on the head. assuming there is no dmg to the casing? VIA machine shop of course. i can carry that bitch in there. 2nd question... could i possibly sell my type-r block as it is? only 3 pistons are worth a damn. 3rd question: what type of b18 block should i put my gsr head on? thanks
Re: What engine block should i get? (tbrown)
1st answer: you expect us to tell you if something is fixable without seeing pics of the damage?
2nd answer: you can sell anything you want
3rd answer: search
3rd answer: search
Re: (DTA-Zombie)
I'd go with an LS block, unless you mean block & pistons. Then it may just be better to buy a GSR bottom end, repair your head, and u'll have a full GSR.
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">I'd go with an LS block, unless you mean block & pistons. Then it may just be better to buy a GSR bottom end, repair your head, and u'll have a full GSR.</TD></TR></TABLE>
My sentiments exactly.
Re: What engine block should i get? (hoo my gosh)
well from what we can see the cylinder wall isnt cracked where the 2nd piston sits. the piston is just crunched. and i cant post pics on this comp..my plugin is broken.
Re: (Syndacate)
Yea i need block and pistons. im thinking a gsr most likely.
carbon fiber coupe
09-26-2011 01:56 PM
shandy
01-05-2010 06:45 PM
