What ECU do i use to bar'd a b16a2 into an obd2a chassis???
Just like the topic says, i was wondering what ecu can i use to bar'd a b16a2 into my obd2a EK?
Thanks in advance
Modified by sparco562 at 6:57 PM 10/3/2006
Thanks in advance
Re: What ECU do i use to bar'd a b16a2 into an obd2a chassis??? (sparco562)
I think the 96+ DelSol VTEC has an OBD2A P30 ECU, or you can get a 99-00 Si OBD2B P2T ECU with an OBD2A->OBD2B conversion harness
Re: What ECU do i use to bar'd a b16a2 into an obd2a chassis??? (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">I think the 96+ DelSol VTEC has an OBD2A P30 ECU, or you can get a 99-00 Si OBD2B P2T ECU with an OBD2A->OBD2B conversion harness</TD></TR></TABLE>
wat he says
wat he says
I could be wrong but i think you have to have an si ecu, without a jumper. i think they wont pass a jumper.
As long as I dont have to take out any more Metal Gears
For it to be completely legit, the motor has to be the same year as the car or newer. so if u are running a 92-95 b16a with an obd2 ecu, i dont think the ref would pass that.
i cant use a 99-00 Si obd2b P2t ECU because my harness is different, and i cannot use a jumping harness since the ref will check the ecu.
So is there a OBD2A USDM b16 ECU? If so do you guys know the ECU code?
Is there a OBD2A P30 ECU?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">in NY nobody checks ****, their lazy, they just plug in the computer no CEL and you pass</TD></TR></TABLE>
Damn i wish i was in NY
Bump for some information
i have an ecu from a 00 si. its a p2t ecu. its for sale. email me at artjaguar@yahoo.com and well talk price or hit me up on aim artlikesfilm
Re: What ECU do i use to bar'd a b16a2 into an obd2a chassis??? (gtz)
Re: What ECU do i use to bar'd a b16a2 into an obd2a chassis??? (89crxsohcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89crxsohcvtec »</TD></TR><TR><TD CLASS="quote">all u would need i think is the ecu corresponding to that motor is would be a P2T</TD></TR></TABLE>
The thing is that i have a obd2a chassis and engine harness and a P2T is an obd2b ECU, so therefore i cannot use a P2T ECU unless i get a jumping harness. In order to get a car bar'd in california, you have to a stock USDM ECU without a jumping harness and all of the emission sensors for that chassis and motor year. I have a 1997 ek, OBD2A, and i understand that I have to get a 1997 motors or new inorder to bar'd the motor into my car. Therefore, I want to swap and bar'd a b16a2(99-00 SI) or b16a3 (Del Sol)into my car but the thing is that i cannot find a obd2a USDM B16 ECU. The only car and ecu that i could think that would work is a 1996-97 Honda Civic Del Sol, but i am not sure what the ECU code is or if there is even a USDM OBD2A B16 ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbabysharkx »</TD></TR><TR><TD CLASS="quote">I could be wrong but i think you have to have an si ecu, without a jumper. i think they wont pass a jumper.</TD></TR></TABLE>
on the contrary....................i BAR'd my 99 LS in my 99 coupe with a jumper because the 99 LS is a OBD2A and my car is OBD2B..................they will pass it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sparco562 »</TD></TR><TR><TD CLASS="quote">So is there a OBD2A USDM b16 ECU? If so do you guys know the ECU code?
Is there a OBD2A P30 ECU?</TD></TR></TABLE>
To answer your question, Yes there is an obd2a P30 ecu out there but remember you will have to use the USDM ecu, not jdm p30. USDM P30 ecu are really hard to find. Best bet is, find someone with an USDM p30 (odb2a) and rent it off him and go ref it then after you pass just slap on a different ecu on.
Re: What ECU do i use to bar'd a b16a2 into an obd2a chassis??? (db8gsr_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8gsr_teg »</TD></TR><TR><TD CLASS="quote">To answer your question, Yes there is an obd2a P30 ecu out there but remember you will have to use the USDM ecu, not jdm p30. USDM P30 ecu are really hard to find. Best bet is, find someone with an USDM p30 (odb2a) and rent it off him and go ref it then after you pass just slap on a different ecu on. </TD></TR></TABLE>
Thanks for the info bro
Re: What ECU do i use to bar'd a b16a2 into an obd2a chassis??? (gsrpusha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrpusha »</TD></TR><TR><TD CLASS="quote">u can run a 96-97 gsr ecu</TD></TR></TABLE>
wont work at all dude....................the ECU needs to be the same years as the motor and car.....................
Re: What ECU do i use to bar'd a b16a2 into an obd2a chassis??? (Superdragr45)
I just swapped a b16a2 in my 98 ek. LIke the other guy said my cars is obd2a and the ecu(p2T) is obd2b therefore I need a obd2a ecu to run properly. So the ecu has to be usdm and not jdm? why is that?and the gsr ecu p72 wont work?
Re: What ECU do i use to bar'd a b16a2 into an obd2a chassis??? (b16-ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16-ek »</TD></TR><TR><TD CLASS="quote">I just swapped a b16a2 in my 98 ek. LIke the other guy said my cars is obd2a and the ecu(p2T) is obd2b therefore I need a obd2a ecu to run properly. So the ecu has to be usdm and not jdm? why is that?and the gsr ecu p72 wont work? </TD></TR></TABLE>
use a jumper to run the P2T. Ref can't say **** about jumper harness.
P.S.
don't know why, but most ref ******* hates honda.
P.S.
killacam661
21
08-07-2007 07:45 AM
poktan
21
04-30-2003 08:50 PM
